Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
Please help - my Pioneer DVR-AO3 drive suddenly stopped getting along with
WinXP SP1, and I can't figure out how to solve the problem. Basically, I
can't read or write any CDs under WinXP, but I can boot from the drive and
I can access it if I use a Win98 boot disk.
When I boot my system into WinXP, I get the following message in my system
event log:
Event Type: Error
Event Source: Cdrom
Event Category: None
Event ID: 11
Description:
The driver detected a controller error on \Device\CdRom0.
This happens during the boot process, with no disc in the drive. I get the
same error when I try to access a disc under WinXP, with the following
occasional companion messages:
Event Type: Warning
Event Source: Cdrom
Event ID: 51
Description:
An error was detected on device \Device\CdRom0 during a paging operation.
--- and... ---
Event Type: Error
Event Source: Cdrom
Event ID: 7
Description:
The device, \Device\CdRom0, has a bad block.
The MS Knowledge Base said the problem is a bad cable, but there are a
couple of problems with this diagnosis. First, the cable is new. Second,
it had been working up until a couple of days ago (don't ask me what
changed, if anything - I have no smegging clue). Third, I was able to
upgrade the DVR-A03's firmware to the latest version (v2.00) without any
errors by booting from a Win98 boot disk and using Pioneer's DOS-based
utility.
I've also searched Google and Google Groups, to no avail. I've tried the
few things I could find on there, but nothing works. Here's what I've
tried so far:
* deleting the DVR-A03 drive in the device manager and letting WinXP
reinstall it
* deleting the secondary IDE channel and letting WinXP reinstall
* installing the latest IDE drivers for my motherboard (a Leadtek 7350KDA
with a SiS 735 chipset)
* making sure all of my burner software is removed and all traces of
drivers like the PxHelp20.sys stuff are gone from the drive and from the
registry
SiSoft Sandra detects the drive and reads its make/model under WinXP, but
it can't gather any other info on it.
Please - ANY help on this would be appreciated!!!
System Specs per SiSoftware Sandra:
Processor(s)
Model : AMD Athlon(tm) XP 1800+
Mainboard and BIOS
Bus(es) : ISA AGP PCI USB FireWire/1394 SMBus/i2c
System BIOS : Award Software International, Inc. 6.00 PG
Mainboard : Leadtek Research Inc. WinFast 7350KDA
System Chipset : Silicon Integrated Systems (SiS) SiS735 CPU to PCI Bridge
Front Side Bus Speed : 2x 133MHz (266MHz data rate)
Installed Memory : 1024MB DDR-SDRAM
Memory Bus Speed : 2x 133MHz (266MHz data rate)
Video System
Monitor/Panel : Dell D1226H
Adapter : RADEON 9550
Adapter : RADEON 9550 Secondary
Physical Storage Devices
Removable Drive : Floppy disk drive
Disk Drive : WDC WD1000JB-32CWE0 (93.2GB)
CD-ROM/DVD : PIONEER DVD-RW DVR-103
Logical Storage Devices
1.44MB 3.5" (A
: N/A
Hard Disk (C
: 93.2GB (31.6GB, 34% Free) (NTFS)
CD-ROM/DVD (D
: N/A
Peripherals
Serial/Parallel Port(s) : 1 COM / 1 LPT
USB Controller/Hub : SiS 7001 PCI to USB Open Host Controller
USB Controller/Hub : USB Root Hub
FireWire/1394 Controller : OHCI Compliant IEEE 1394 Host Controller
Keyboard : PC/AT Enhanced PS/2 Keyboard (101/102-Key)
Mouse : HID-compliant mouse
Human Interface : HID-compliant device
Human Interface : USB Human Interface Device
MultiMedia Device(s)
Device : Creative SB Audigy
Device : Creative Game Port
Operating System(s)
Windows System : Microsoft Windows XP Professional Ver 5.01.2600 Service
Pack 1
Network Adapter(s)
Networking Installed : Yes
Adapter : Realtek RTL8139/810x Family Fast Ethernet NIC
