Problem with asus p3b-f and pci wireless netcard
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi
Newest bios on asus p3b-f
Windows xp with.
PCI wireless netcard is Trendnet tew-423pi, 54 Mbit/s
http://www.compumail.dk/vare-oversigt.php?varenummer=94303&type=hardware
Is there something rotten about old motherboards and wireless pci
netcards ?
The router is Trendnet tew-432brp.
http://www.compumail.dk/vare-oversigt.php?varenummer=94301&type=hardware
On others a little bit more modern MB this wireless works directly
with drivers even without the utility (Trendnet) installed, - and on
even longer distance.
Any ideas or similar experiences ?
mvh
John
9 answers Last reply
More about problem asus wireless netcard
  1. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    On Mon, 18 Apr 2005 22:04:30 +0200, JK <johnknuhtsenSP@Mmail.dk> wrote:
    >Hi
    >Windows xp with.
    >netcards ?
    >mvh
    Check the system requirements for the card and see what minimum revision PCI
    support it requires.
    The P2 and P3 family motherboards (440BX chipsets) supported PCI 2.1.
    It's not unusual to find modern PCI cards that require 2.2 or higher...
    /daytripper
  2. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    On Mon, 18 Apr 2005 16:25:04 -0400, daytripper
    >>Hi
    >>Windows xp with.
    >>netcards ?
    >>mvh
    Thank you, it requires PCI 2.2
    best regards
    John
  3. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    >>Hi
    >>Windows xp with.
    >>netcards ?
    >>mvh
    Does anybody know of a brand having a wireless pci netcard only
    requiering pci 2.1 ?
    I have looked at some linksys and dlink cards and did not find it.
    Any ideas ?
    TIA
    John
  4. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    >>Hi
    >>Windows xp with.
    >>netcards ?
    >>mvh
    It seams that you are wrong. The manual states, that pci is 2.2, but
    in bios 2.1 pci can be disabled/enabled.
    I will try with changing bios setting, and/or refresh windows.
    best regards
    John
  5. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    In article <ldv961lj223q45mjv2uv3dg0epfk6rncoe@4ax.com>, JK
    > best regards
    > John
    What exactly is the problem you are having ?
    Some 440BX motherboard simply ignore certain PCI cards.
    Is your wireless card ignored ? Or is it detected
    and resources assigned by the BIOS ?
    If the problem is transmission distance, that is
    harder to explain as a motherboard fault.
    Paul
  6. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    >> best regards
    >> John
    The problem is that wireless card is not working. Utility for the card
    not working, and not working with standard XP either.
    It cannot connect.
    best regards
    John
  7. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    In article <7boa615gba35mf5hcqb7g2gl9sm74unjp9@4ax.com>, JK
    > >> best regards
    > >> John
    > It cannot connect.
    > best regards
    > John
    The reason I ask, is I wonder if the card can be seen in
    Linux but not in Windows ? Is the card completely invisible
    to any software probes ?
    Paul
  8. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    "JK" <johnknuhtsenSP@Mmail.dk> wrote in message
    news:fd48619kltkg7p2ddrgd1vs6jqcam4981m@4ax.com...
    > Hi
    > Windows xp with.
    > netcards ?
    I've always had rotten luck getting wireless network cards (Linksys and
    D-Link) to work on older motherboards. I monkeyed around with BIOS settings
    after doing research online, I updated drivers, blah blah, but no luck.
    For older systems, I've had much better luck with USB wireless network
    adapters that just plug into a USB port. That's still no guarantee, however,
    because sometimes it takes a couple tries before the connection occurs. With
    Linksys equipment, the newer (v. 2 or higher) USB wireless adapters seem to
    be much better at grabbing and holding a connection.
  9. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    On Wed, 20 Apr 2005 22:02:32 -0400, "Hackworth"
    >> Hi
    >> Windows xp with.
    >> netcards ?
    That is what I will try, yes. Usb 11 Mbit/s, because usb 2.0 pci
    adapters requires pci 2.2 also.
    best regards
    John
Asus Wireless Trendnet Motherboards
