Tom's Hardware > Forum > Games General > Games General Discussions > Help! Stuck any tips? Please
Forum Games General : Games General Discussions - Help! Stuck any tips? Please
Archived from groups: alt.games.halo (More info?)
I have tried over 130 times can't get past,
Cairo legendary, second room of when Alein's are docked to ship, two
little grunt's up top kill them no problem, behind them in ships
opening are a few elites with grunts, can't get past the 3rd wave of
aleins that come out, I have thrown plasmas on them after sneaking up
and they don't die, I have shot every piece of ammo around double and
single till it is exhuasted, help,
I blow through heroic but can't go far in legendary
any tips in that room?
thanks
Sponsored Links
kkdisc@bellsouth.net (mullet) wrote in
news:6688e4e.0411290947.3169e58a@posting.google.com:
> thanks
**** maybe spoiler *****
It took many many tries for me to finish that room. Finally, went back
& started the whole game again, using very very few grenades on the
first boarding level, then pick up and put down every weapon you can
find before activating the checkpoint as you approach the second
boarding level. ESPECIALLY the 2 needlers must be saved!!
I found that every weapon I touched was still there later when I needed
it, if I didn't "pick it up and put it down" it had evaporated by the
time I needed it.
Do your best to clear the room. I used dual plazma rifles most of the
time. After the wave with Elites with dual weapons comes out, throw
some grenades and run like hell back to the original room, go back up
top and get some grenades, and get your dual needlers and rock them.
Also found with dual neelers jumping high from cover & shooting needlers
together works well .... most of the time.
BeaglePig
Reply to Anonymous
BeaglePig <BeaglePig@notreal.com> wrote in
news:Xns95B091922E803BPnotreal@140.99.99.130:
>> thanks
> back & started the whole game again, using very very few grenades on
> the first boarding level, then pick up and put down every weapon you
> can find before activating the checkpoint as you approach the second
> needed it, if I didn't "pick it up and put it down" it had evaporated
> by the time I needed it.
> needlers together works well .... most of the time.
> BeaglePig
I'll add, I'm currently in the "prophet punching room" and am having a
hell of a time... anyone who has tips for completing this on legendary,
they would be appriciated.
BeaglPig
Reply to Anonymous
The trick here is to be patient and prepare to die a dozen or so times.
After dying, revert to save immediately and try again. Move fast. The trick
is to get the rythym down to kill a few swordies then jump the prophet to
bitch slap him. Then, after he kicks you off, hopefully you can get away and
hide shortly, before the new swordies come out. Avoid/run away from the
prophet guards with the dual lasers. They will kill you very quickly. Don't
be a fraidy cat though. Look for the chance to run up and throw a grenade in
a guards face.
Eventually, you will advance your checkpoint and have a few prophet smacks
behind you.
I think the trick is not to hesitate, because the guards WILL NOT stop
coming out. Be tenacious. It helps to get pissed off.
A low tech way to beat the level. Good Luck,
pez
> BeaglPig
Reply to Anonymous
There are 565 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Related Content
