Building new system - advice appreciated!
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Well, after much debate I think it may be time to get a new PC. I have been
reluctant to as we just bought a new PC last year, but a couple of things
have changed my mind:
It only has a PCI slot for video card upgrade, no AGP. And in any case, the
monitor has this wacky ‘digital +’ plug that appears to only fit with Fujitsu
computers. No DVI or VGA adapters appear to be adaptable. I went ahead and
bought a Ge-Force 5600 PCI video card that does get me into the market for
Direct X 9b games, but the performance is sketchy (always have to set to
lowest options, and then still get lag in games like BFV). I also bought an
old cheap VGA monitor, but it hurts my eyes. Not thrilled with the prospect
of shelling out a couple of hundred dollars more for a new DVI monitor to
equal the original, and still being yesterday’s PCI technology, I thought
getting a new system might be in order. Too bad as Fujitsu has a good
reputation for quality here, and I am happy with the PC otherwise. And it’s
all still under warranty.
Keep in mind I am in Japan, and the language barrier makes everything more
difficult. Also, selling/buying used computers is not common here, so I’ll
probably have to take a huge hit if I go that route. We got the system for
130,000 yen (about $1200 US), much cheaper than normal retail. Anyway, if
possible I would like to try and salvage something from it to be cost
effective. Is it possible to do this? The low end SiS 740 video card is
built into the mobo, and there are no AGP slots.
Make/name: Fujitsu FMV-Deskpower (Model: CE21C).
AMD Anthalon XP 2100+
266 MHz system bus clock
256 MB memory (plus 512 MB stick I added)
120 GB HD
Accessories: 17� flatscreen monitor with built-in speakers, laser mouse,
DVD-R CD-RW drive, Ge-Force 5600 PCI card.
I play a lot of games, so would like to have a decent system, but don’t need
to get an outrageously new/expensive type. Any advice or recommendations
greatly appreciated!
6 answers Last reply
More about building system advice appreciated
  1. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    May I suggest that you consider a minimum specification as follows:
    • Intel Pentium 2.8Ghz CPU @ 800 FSB CPU 1Mb [or Prescott]
    • 512Mb DDR Ram @ FSB400
    • 120Gb IDE Hard Drive @ 7200 RPM or SATA Hard Drive
    • Motherboard with:
    o AGP 8X graphics interface
    o Integrated 5.1-channel 3D audio
    o Integrated USB 2.0 (Total 8xPorts)
    o Integrated 10/100 Network Card
    o SATA and ATA Interfaces
    o Intel Prescott Ready!!!!
    • nVidia FX5700 256Mb Video Card
    • 16x DVD Rom Drive or DVD Burner On Request
    • 1.44Mb Floppy Drive
    This should cost less than US$700 including the case with a 350W or 400W
    power supply [definitely required for the CPU and Memory]. If you want to
    reduce your costs, find an AMD CPU / MOBO combination with the other specs of
    same level and it will save you US $100 over the Intel CPU without affecting
    gaming performance.
    Given what you already 'have' in your current config: re-usable items include:
    .. DVD-R drive [US$ 40]
    .. CD-RW drive [US$40]
    .. Floppy Drive [US$ 10]
    .. keyboard [US$ 20]
    .. mouse [US$ 20]
    .. monitor / speakers [US$ 300]
    > 120 GB HD
  2. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    You can almost get these exact specs for under $400. Check out this deal:
    http://www.fatwallet.com/forums/messageview.php?catid=18&threadid=353580&highlight_key=y&keyword1=Dell
    Nathan McNulty
    > • Motherboard with:
    > gaming performance.
    > . keyboard [US$ 20]
    > . mouse [US$ 20]
    >>monitor has this wacky 'digital +' plug that appears to only fit with Fujitsu
    >>equal the original, and still being yesterday's PCI technology, I thought
    >>reputation for quality here, and I am happy with the PC otherwise. And it's
    >>difficult. Also, selling/buying used computers is not common here, so I'll
    >>120 GB HD
    >>I play a lot of games, so would like to have a decent system, but don't need
  3. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    Hi guys-
    Thanks for the link Nathan. Unfortunatley Dell doesn't appear to ship to
    Japan. But those specs are helpful. Also, as I mentioned the monitor won't
    fit anything but some Fujitsu PCs. Is my Fujitsu mobo and processor useless
    for rebuild as there is only PCI slots available?
    > Nathan McNulty
    > > • Motherboard with:
    > > gaming performance.
    > > . keyboard [US$ 20]
    > > . mouse [US$ 20]
    > >>120 GB HD
  4. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    They are not useless as there are PCI Video cards, but you will probably
    not have very good performance from your existing system. If this
    monitor is proprietary, you are going to be hard pressed to find one
    that will work with it.
    Nathan McNulty
    jonnyd wrote:
    > Hi guys-
    >>Nathan McNulty
    >>>• Motherboard with:
    >>>gaming performance.
    >>>. keyboard [US$ 20]
    >>>. mouse [US$ 20]
    >>>>120 GB HD
  5. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    I understand that Japanese companies sell a lot of equipment
    in Japan that does not meet international standards, it is
    not intended for export and so finding standard hardware is
    often not possible.
    If you are visiting/working in Japan and want to buy a
    computer (or anything else) check whether it is an
    exportable product that is supported internationally.
    The people think the Constitution protects their rights;
    But government sees it as an obstacle to be overcome.
    "Nathan McNulty" <nospam@msn.com> wrote in message
    news:Or$vBP1iEHA.2688@TK2MSFTNGP15.phx.gbl...
    will probably
    If this
    to find one
    | Nathan McNulty
    | jonnyd wrote:
    | > Hi guys-
    appear to ship to
    | >>Nathan McNulty
    as follows:
    | >>>. Intel Pentium 2.8Ghz CPU @ 800 FSB CPU 1Mb [or
    Prescott]
    | >>>. 512Mb DDR Ram @ FSB400
    | >>>. 120Gb IDE Hard Drive @ 7200 RPM or SATA Hard Drive
    | >>>. Motherboard with:
    | >>>. nVidia FX5700 256Mb Video Card
    | >>>. 16x DVD Rom Drive or DVD Burner On Request
    | >>>. 1.44Mb Floppy Drive
    with a 350W or 400W
    | >>>gaming performance.
    | >>>. keyboard [US$ 20]
    | >>>. mouse [US$ 20]
    a couple of things
    into the market for
    new DVI monitor to
    Fujitsu has a good
    retail. Anyway, if
    from it to be cost
    | >>>>120 GB HD
    | >>>>Accessories: 17" flatscreen monitor with built-in
    or recommendations
  6. Archived from groups: microsoft.public.windowsxp.hardware (More info?)
    As many here do, I work on computers. It is very hard to transfer HW from
    proprietary systems to standard systems. These components are made
    specificly for these systems and do not migrate well. Even those items that
    you think may work fine (CD ROM/DVD ROM drives for example) do not as face
    plates, size and demensions may be different from the standard.
    Also, you may or may not benefit from the fact that slowly the market is
    beginning to look forward to PCI Express for video which intails using
    completely new MB/CPU and associated HW. You may get a bargain on some of
    the current systems which do not have options like PCI Express and DDR2.
    However, probably sooner then later new SW titles (read games) will be
    optimized for these latest HW changes.
    It well may be a pain, but it may be worth while to consider having a system
    built/purchased in the states and have it shipped to you by family/friends.
    Just make sure that who every makes the system understands that it will be
    used internationally.
    Just my 2 cents on the matter...
    Len
    "jonnyd" <jonnyd@discussions.microsoft.com> wrote in message
    news:8394DE30-C702-4D0F-9CD8-76A501B52E1B@microsoft.com...
    > Hi guys-
    > won't
    > useless
    >> deal:
    >> Nathan McNulty
    >> > . Intel Pentium 2.8Ghz CPU @ 800 FSB CPU 1Mb [or Prescott]
    >> > . Motherboard with:
    >> > 400W
    >> > to
    >> > specs of
    >> > affecting
    >> > gaming performance.
    >> > include:
    >> > . keyboard [US$ 20]
    >> > . mouse [US$ 20]
    >> >>been
    >> >>things
    >> >>case, the
    >> >>Fujitsu
    >> >>ahead and
    >> >>for
    >> >>to
    >> >>bought an
    >> >>prospect
    >> >>to
    >> >>thought
    >> >>it's
    >> >>more
    >> >>I'll
    >> >>for
    >> >>if
    >> >>is
    >> >>120 GB HD
    >> >>Accessories: 17" flatscreen monitor with built-in speakers, laser
    >> >>mouse,
    >> >>need
    >> >>recommendations
Windows XP
