G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I've got an A7V333 Mother Board that I've been using for some time as
multimedia PC. I decided to upgrade the hard drives to a raid 0 or striped
aray for the speed about a year ago. It's been buggy sense then, but worked
ok, and it was faster than standard IDE.
Now I reboot this morning, and windows tells me it can't find drive C: .
So how did it get into windows? I don't know.
I try to reboot, and it shows no sign of a hard drive. The Promise
Fasttrack software says the array is functional, but the computer won't
boot from hard drive or from CD. I don't have a clue whats going on.
I tried reloading windows xp but it just hangs when it "checks your systems
hardware" so it doesn't even get started.
I tried using a western digital utility to check the drives (2-200 gig WD
drives), and the drives check ok.
I tried reinstalling the bios, made no difference.
I tried reloading the Fasttrack drivers, but I can't get it to boot to the
point where I can.
I went into Fasttrack setup, and deleted the array, then setup up a new
array, with no problem. This tells me the drives are ok also.
If the drives are ok, and Fasttrack is working how come the system doesn't
see the drives?
Help!!
I may be overlooking something, but I have checked the bios settings over
and over again, they are still set to ATA in PCI config, and boot ATA first
in boot section.
Any help much appreciated!!
Thanks in advance Mike B.
point where I can.
see the drives?
Help!!
in boot section.
