Archived from groups: microsoft.public.windowsxp.hardware (More info?)
my specs:
Motherboard: Intel D850GB,
CPU: P4 1.75Ghz
Video Card: ATI Radeon 9600 128MB,
Monitor: Gateway EV700
Memory: RIMM RAMBUS 512MB,
Hard Drive: 2x80GB HD
450W PSU
Now this setup has worked before, but I guess multiple instances of taking
it apart and putting it back together has taken it's toll.
When I power up my system, the fans all come on and the hard drive starts
making noise, so I think it's booting up. However my monitor is not getting
any signal. The monitor will start playing the test image when it gets
attached to the vid card, but it won't get any actual video data.
Now the vid card and monitor work fine when used on the other motherboard,
so I think the issue might be with this mobo, even though it worked fine
before.
And I don't think the problem is with me attaching the vid card faultily
because when i tried with my Geforce 3, the fan on that will turn on when I
boot up the system.
Well I hope I explained my problem thoroughly enough for you to help me.
"TheBladeRoden" <TheBladeRoden@discussions.microsoft.com> wrote in message
news:78FFDD56-8F8B-4A98-BD16-4ABCB5BAF543@microsoft.com...
> my specs:
> CPU: P4 1.75Ghz
> 450W PSU
> getting
> before.
> I
> boot up the system.
Take it all apart again, leaving just the motherboard, memory, processor,
and video card. Power supply, obviously. You can do this outside the case,
if you want, to verify that nothing on the case is shorting. Leave the
drives unplugged from power, and the ide/floppy cables unplugged from the
motherboard. See if it turns on. If no, you can remove memory and/or vid
card. You should get an interesting beep from the motherboard. If no beeps,
the motherboard is likely the problem, as it should at least be able to
signal a video or memory error.
If it does post with just the mobo, proc, mem and vid, start adding
components back one at a time. Either you'll find one that's gone bad, or
you'll find out that there was an assembly problem before.
Ok so i stripped the mobo of almost everything. When it doesn't have video
card or memory, I get 3 long beeps. With a vid card and without memory I get
3 long beeps. When I have memory but no vid card I get no beeps. And when I
have both vid card and memory I get no beeps. In all cases the fans turned on
but there was still no video signal.
D.Currie's suggestions are all good.
There's more troubleshooting information and general
motherboard info available at
http://support.intel.com/support/m [...] ktop/sb/CS
-010256.htm .
In addition to Currie's suggestions, either check the
power leads with appropriate equipment (if available), or
consider temporarily replacing the power supply. Sometimes
a faulty power supply can cause this sort of issue,
especially when only one or a few leads die.
If you do trace the problem to the motherboard, don't give
up hope yet. I've dealt with an Intel motherboard with
onboard video that exhibited a similar issue when first
installed. In that case, the CMOS was somehow corrupted
and had to be reset. If you run out of other options,
consider trying to reset the CMOS.
Looking through the manual, it appears there's a jumper
you can move to load BIOS defaults, so that may be worth a
try. Also note that if the jumper was accidentally
removed, the board may be trying to recover its BIOS using
a floppy. So check the jumper to make certain it's in the
proper place.
>-----Original Message-----
wrote in message
>> my specs:
>> CPU: P4 1.75Ghz
>> 450W PSU
instances of taking
toll.
hard drive starts
monitor is not
>> getting
image when it gets
video data.
other motherboard,
>> before.
vid card faultily
will turn on when
>> I
>> boot up the system.
for you to help me.
memory, processor,
outside the case,
shorting. Leave the
unplugged from the
memory and/or vid
least be able to
start adding
that's gone bad, or
before.
Just as an addition to my prior response, given the new
information:
3 beeps indicates there's an error in the first 64k of
memory. That's hardly surprising, since you get 3 beeps
only when you remove the memory.
The good new is this indicates the motherboard is working,
at least to some extent.
memory, processor,
shorting. Leave the
unplugged from the
memory and/or vid
least be able to
start adding
that's gone bad, or
before.
doesn't have video
beeps. And when I
How 'bout the obvious... cable, connections...
> my specs:
> CPU: P4 1.75Ghz
> 450W PSU
getting
> before.
I
> boot up the system.
> my specs:
> CPU: P4 1.75Ghz
> 450W PSU
> getting
are there any abnormal POST beep codes?
AGP video card or CPU firmly seated in their sockets?
possibly bad/failing RAM, if more than 2 RAM modules, try populating only
Bank0, alternating b/w modules to see if one of them is bad. unplug all PCI
cards and disconnect all other hardware from mainboard except keyboard and
AGP video card/monitor while testing. when pulling/plugging adapter cards,
turn OFF AC to the power supply, allow at least 30seconds for power supply
to discharge (PCI slots are live, even when computer is turned off). if
computer is plugged into a power bar, turn off the power bar switch but
leave the computer and power bar plugged in, that will keep the chassis
grounded while you work on the machine, so if your skin maintains contact
with the grounded chassis, static will not build-up on your body.
diagnostic beep codes for intel boards:
http://www.intel.com/support/mothe [...] 010249.htm
support for d850gb board:
http://support.intel.com/support/m [...] op/d850gb/
d850gb issues:
http://support.intel.com/support/m [...] issues.htm
AGP compatibility:
http://support.intel.com/support/m [...] 009010.htm
d850gb RAM:
http://support.intel.com/support/m [...] 013246.htm
francis
i assume you don't have another video card laying around (PCI or AGP) that
you could use to test the Intel board?
francis
Perhaps it has something to do with my attempts to replace the bettery a few
das ago.
news:FE464DDD-1383-4C9B-8D99-AD5F01504E07@microsoft.com...
> few
> das ago.
ummm, interesting... replacing the battery should not corrupt the BIOS,
although the board may lose system parameters stored in the CMOS, in which
case the system is supposed to reload the default parameters from in the
BIOS
who knows, you may need to put the board into BIOS recovery mode (see url
below), i've done this with an Intel board in the past, you need a floppy
disk with the BIOS image file on it, set jumper J8C2 to recovery mode, put
disk in drive, turn ON computer and system will reload the BIOS boot block.
when the process is complete, it notifies you with a beep. turn off the
power, reposition the BIOS recovery jumper to normal mode, start system.
Intel® Desktop Board D850GB
Configuration Jumpers
http://support.intel.com/support/m [...] 013239.htm
Recommended BIOS Version
http://support.intel.com/support/m [...] 013260.htm
Intel BIOS Recovery Process:
http://www.intel.com/design/motherbd/recoverybios.htm
http://www.intel.com/support/mothe [...] prd952.htm
francis
On this page
http://downloadfinder.intel.com/sc [...] me+Edition
all I'm seeing are .exe files and I think I need a .bio file
> francis
I've used an ATI Radeon 9600 and a GeForce 3 with similar results
> francis
news:117C0409-71AA-4C83-BEC3-71D6048338F9@microsoft.com...
> On this page
go here:
click on the 'BIOS P06 or later' link, chose OS Independent from the
listbox, press GO, you will see the BIOS for the D850GB. download the BIOS
self-extracting archive to a temporary directory, open a command-console
(dos prompt) in the temporary directory, run the 'gb-p18.exe' executable, it
will self-extract to the same directory, put a floppy in the drive, type
RUN.BAT, press Enter. a bootable floppy with the .BIO files will be
created. when completed, move the floppy disk into the drive of the Intel
machine, configure the BIOS jumper for recovery mode, start the system,
there will be NO video, wait for BIOS boot block to be recovered from the
floppy, the system should turn OFF when the process is complete. move
jumper back to normal position, restart system. you may also want to use
same the same floppy to reflash the BIOS, as i'm not sure if the the
recovery process only updates the boot block or the entire BIOS.
goodluck
francis
the following may also prove helpful:
http://support.intel.com/design/mo [...] rdbios.htm
francis
I am surprised nobody has metioned this yet. You have an i850G chipset.
This means you have an integrated video controller. By changing the
battery out, you have reset the BIOS settings which default back to the
integrated video card. Try connecting the monitor to the other video
source
Nathan McNulty
TheBladeRoden wrote:
> my specs:
> CPU: P4 1.75Ghz
> 450W PSU
> before.
> boot up the system.
How about the onboard video? See my other post
Nathan McNulty
>>francis
"Nathan McNulty" <nospam@msn.com> wrote in message
news:%23W9TpK1iEHA.2664@TK2MSFTNGP11.phx.gbl...
the Intel D850GB does not have onboard video
francis
news:etGnoJ1iEHA.2664@TK2MSFTNGP11.phx.gbl...
>This means you have an integrated video controller. By changing the battery
>out, you have reset the BIOS settings which default back to the integrated
>video card. Try connecting the monitor to the other video source
francis
"francis gérard" <spam@spamcop.net> wrote in message
news:%23RXYSb4iEHA.3664@TK2MSFTNGP12.phx.gbl...
>>source
and of course, you're right, that was also the first thing i thought of, but
being unfamiliar with the D850GB, i looked it up on the Intel site to see if
it had integrated video, which it does not
francis
Bah. I'm doomed I'm doomed! I removed the jumper like said but alas no
activity from the A drive
"francis gérard" <spam@spamcop.net> wrote in message news
DazVg4iEHA.556@tk2msftngp13.phx.gbl...
>>>source
Do you think Nathan is so dumb, that he couldn't grasp the first time you told him there is no integrated video on that particular MOBO model (at least until he replied to your initial response), or do you just like seeing yourself repeat the same thing over and over again?
news:986B78E2-5793-48C9-9702-5A42927C7495@microsoft.com...
doh!
btw, you don't need video card installed, just cpu, ram in bank0, and floppy
drive to restore the BIOS bootblock.
if the BIOS recovery mode doesn't work, then there's something wrong with
the board. remove it from the enclosure, flip it over and carefully inspect
the bottom for shorted pins, broken circuit traces, flecks of
debris/conductive material, use alcohol to clean if necessary. rest the
board on non-conductive, antistatic surface, remove cpu and ram and other
peripheral hardware from the board, inspect them carefully for damage.
start over, plugin CPU, make sure it's properly seated and locked. do the
same for the RAM, bank0 only (2modules). don't reassemble the board inside
the enclosure just yet. either remove the power supply and floppy drive
from the enclosure or flip on its side, close enough so that the power
supply leads and floppy cable will plug into the mainboard. check
everything over (at least twice), connections all good, no stray conductive
materials to cause a short, etc. start her/him up.
i assume you've tested all peripheral hardware, cpu, ram, video, etc in
another machine (mainboard)?
tip - the antistatic bag that the mainboard was packaged in would make a
good antistatic surface to rest the board on while it's being worked-on
outside of the enclosure.
francis
"Tom" <noway@nothere.com> wrote in message
news:urbBku5iEHA.596@TK2MSFTNGP11.phx.gbl...
> told him
> he
> repeat the
who pissed in your wheeties this morning?
and thanks for contributing absolutely *nothing* of value to this
discussion.
you don't like what i have to say... BLOCK ME and FO!
francis
JjEw35iEHA.140@TK2MSFTNGP12.phx.gbl...
>> told him
>> he
>> repeat the
> discussion.
So, you answer a question with a question; I guess ol'Nathan will just have to live in condescension.
Wow, getting pissy regarding what you *think* I like or don't like (though I never posted a word to convey that thought)! Do yourself a favor, don't assume so much, and direct your reply according to the query.
Anyway, what is your answer to the question?
> francis
news
fAgQJ6iEHA.1348@tk2msftngp13.phx.gbl...
look fool, do NOT put words in my mouth, i did not imply for a millisecond
that nathan was "dumb" (YOU said that, NOT me). furthermore, i would not
say any such thing about Nathan, as i've read many of his articles, he,
unlike yourself, is one of the few who do NOT say dumb things. if you had
read more carefully, instead of nitpicking about newsgroup etiquette, you
would have seen that i agreed with Nathan's assertion about the onboard
video, and i merely followed-up with a correction about the D850GB. i think
Nathan is SMART enough to figure that out on his own, and doesn't need
persnickety pricks like you to hit-n-run on a discussion thread without
contributing anything of value.
> to the query.
i'll stop assuming when you stop your bitching about my articles
you idiot... haven't you been following this thread??? i think not. READ
CAREFULLY, i've contributed many follow-up articles to the original query.
francis
"francis gérard" <spam@spamcop.net> wrote in message news:e64kcW6iEHA.140@TK2MSFTNGP12.phx.gbl...
> i think
LOL! Nathan is smart enough (I know that myself), but you sure didn't post like that. Here are your post in order:
1: "Nathan McNulty" <nospam@msn.com> wrote in message
> francis
2: "Nathan McNulty" <nospam@msn.com> wrote in message
> francis
3: > "francis gérard" <spam@spamcop.net> wrote in message
>>> source
> being unfamiliar with the D850GB, i looked it up on the ****Intel site to see if
> it had integrated video, which it does not**** (**** added to show the same thing you > stated twice before)
> francis
>> to the query.
Who said I was bitching, I simply asked question, then you bitched!
Your first two were not follow ups, as I posted above, rather exact simplistic replies, the third showed you felt the need to explain what you probably felt what he needed as an explanation. Anyway, you accuse me of not following the thread, when I ask you why you made the same simple point to Nathan three times. Ever wonder why you feel the need to be sure someone follows your thread?
I'll check back to see if you, somehow, interpret this latest reply to you as a form of "bitching" LOL!
Before this post turns into WWIII
I am used to Intel Chipsets such as i865G being their integrated
graphincs. I simply assumed it was 850G for the chipset. This was MY
fault for not looking this up first before posting.
As for francis, he did exactly what I would have done. The two posts
were seperated and I would have followed up both of them just as he did.
As for this from francis' thread: "furthermore, i would not
unlike yourself, is one of the few who do NOT say dumb things.". I have
had my moments of stupidity. We are all allowed those moments
To Tom, thanks for defending me. It is always great to know that others
respect my opinions as well as those of others (especially the MVP's who
try their hardest to provide consistent help). I really enjoy the level
of intelligence and willingness to help that is so easily seen
throughout these newsgroups.
Sorry I didn't repsond earlier to this post, but I was at work all day
and just got home
Nathan McNulty
>> i think
>>francis
>>francis
>>>>source
>>http://support.intel.com/support/motherboards/desktop/d850gb/
>>francis
>>>to the query.
news:uvIXRy8iEHA.1712@TK2MSFTNGP09.phx.gbl...
> LOL! Nathan is smart enough (I know that myself), but you sure > didn't
> simplistic replies,
> he needed as
> ask you why
> feel the need
you're not following the entire discussion... go to the source of the
thread, at the top, starting with the original query from 'TheBladeRoden',
expand all the threads... you will see that there are lots of helpful
followups from me. i count 7 articles from myself, not including the
followups to nathan and this bullsh*t with you! that makes at least 10
followups from me in this discussion thread.
look, it's your problem that you can't follow a newsgroup discussion... and
this bitching and banter is useless. you've added your 2cents worth
(literally), now piss-off if you can't say or add anything useful. i'm
tired of your idiocy.
francis
4ZLFq9iEHA.2436@TK2MSFTNGP09.phx.gbl...
You have to be one of the most fragile people I've encountered in these groups!
news:%23ypnCz9iEHA.3632@TK2MSFTNGP09.phx.gbl...
news
> groups!
opinions are just that
ask me if i care... NO
francis
There are 1269 identified and unidentified users. To see the list of identified users, Click here.
