Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hello all.
I have the subject motherboard and am getting very poor LAN performance
using the on-board Marvell LAN controller. More specifically, the
computer shares a directory and when I attempt to copy files from the
A8V, the network utilization bar LED's on my 3Com 100 MB hub spike and
vanish as the transfer occurs. A 100 MB file may take 8 minutes.
Adding a separate 3Com 3C905 will copy the same file in a more
reasonable 10 seconds, and the hub meter stays peaked without the
spiking I described.
System has
1 GB memory
3000+ Winchester core not overclocked
I have:
Performed a repair operation on the Marvell NIC
Rebooted and even cleared the CMOS
Powered off the PC for a hour
Manually changed the speed to 100 MB Full from the default Autosense
Changed cables to the hub
Does anyone have any additional tips that might help in diagnosing and
correcting this problem? If the on-board LOM has failed, then how are
the ASUS folks at warranty repair and return?
Thanks in advance,
PB
Hello all.
System has
1 GB memory
I have:
Thanks in advance,
PB
