A7V600 & A7V600x have no built-in audio?
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Are these two A socket boards the only ones Asus has "without" audio
built on?
4 answers Last reply
More about a7v600 a7v600x built audio
  1. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    In article <7jdh81dqepng8nmdba8588j0rb6pbvc1e1@4ax.com>, Mach 1
    > built on?
    Here is a list off the Asus site. None of the products are
    listed as "WOA". I think everything has some kind of AC97
    or Azalia chip on it. I would hope every available variant
    would be on this list, because each product would need a
    unique SKU in order to be sold in stores.
    http://usa.asus.com/wheretobuy/SKUs/Motherboard_SKUs.pdf
    I tried search terms like "asus" and "woa", but only older
    products are available WOA.
    Paul
  2. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    Just dont see the need for a audio chip on-board if you have a sound
    blaster.
    Course as cheap as they are and I spose you can disable them why not.
    >> built on?
    > Paul
  3. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    "Mach 1" <fordcoupe@att.net> wrote in message
    news:7jdh81dqepng8nmdba8588j0rb6pbvc1e1@4ax.com...
    > built on?
    I have both of these boards and the both have onboard audio. Easy to disable
    if you do not want to use them.
  4. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    Thanks dude.
    Well as far as I can tell all of their socket A boards have audio. So
    I might as well move up to a nicer board than the 600's
    >> built on?
Asus Audio Socket Motherboards
