Tom's Hardware > Forum > Computer Peripherals > Printers > HP 3500 color laser color matching problem
Forum Computer Peripherals : Printers - HP 3500 color laser color matching problem
Archived from groups: comp.periphs.printers (More info?)
I have a HP 3500 color laser. It prints well except for one color. I
was wondering if other HP 3500 owners could open and print an Excel
spreadsheet file. The block should print as light blue, but it prints
as light green. Do you have the same problem?
The file is located at
http://www.vanfm.com/colorhp3500.xls
Further detail is here at
http://www.vanfm.com/hp3500colorproblem.pdf
Please post replies here.
Sponsored Links
In message <b754a3b7.0405251512.22fef55d@posting.google.com>, Tom
<threeisl@yahoo.com> writes
Have you got the laser set with some sort of color 'improving' setting?
Try turning off all the colour help/calibrating setting in the printer
properties.
Timothy Lee http://www.wightproperty.com
tlatwightpropertydotcom
Reply to Anonymous
- 0 +
SOLUTION FOUND
Solved blue printing as green problem with May 31 2004 firmware update
for CLJ 3500 - worked like a charm
http://h20000.www2.hp.com/bizsuppo [...] cale=en_US
Reply to Tom
There are 1277 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
