Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Two are listed below.
WRITTEN BY: RANDY (AUG 29 2004 4:08AM PDT)
I have a remarkably similar problem in that I just
installed an Artec 16x DVD-ROM drive with a Plexwriter
8/4/32A CD-RW already in use. My bios detects both drives
fine as does Windows XP, but the DVD-ROM only worked at
first install; and after that (even though detected) will
not read ANY disks. Windows XP reports 'no device
conflicts' and 'This device is working properly', but
that
is not true with the DVD-ROM (the CD-RW reads disks
fine).
I've tried multiple primary and secondary IDE connection
and jumper configurations with the same results; I even
went out and bought a PCI Ultra ATA IDE controller card,
put only the DVD-ROM over to it, and it WORKED!
Unfortunately, it only worked the first time (as before),
and after the next computer boot up, again can no longer
read ANY disks. Both drives reported fine by Win XP w/no
conflicts. HERE'S THE KICKER: IF I DISABLE THE CD-RW IN
WINDOWS DEVICE MANAGER, THE DVD-ROM STARTS WORKING FINE!
All my drivers are up to date. It appears there is some
sort of conflict between the drives, but it is beyond me
to figure out how to get both them to work at the same
time. I've tried all possible separations on the IDE
cables (and the PCI card), but that only results in one
or
the other device stopping working. Please, can someone
help me get both drives working at the same time?
WRITTEN BY: TONY (AUG 28 2004 3:50PM PDT)
>-----Original Message-----
>I accidentally posted in General, but anyways, my HP CD
>Writer won't work, won't even read any kind of a cd.
>However, it does show in My Computer, Windows Explorer,
>and Device Manager (as working properly). When I put in
>the driver CD (in another CD Drive) the driver says that
>the Hp CD Writer that I have is not IDE compatable, but
>at boot up, when PC detects IDE hware, it detects the CD
>Writer. And another thing, That second drive is a DVD
>drive. Works fine, but where can I get a compatable DVD
>decoder. Like power dvd or something. It is a toshiba I
>think. Thanks in advance for suggestions.
>Tony
that
fine).
or
>Tony
