Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
marcbkk wrote:
> I am running an ASUS P4P800S-X Motherboard with a P4 3.0GHz CPU, 1GB
> of DDR Ram consisting of two 512 chips, and an ASUS Radeon 9550SE VGA
> card.
> Recently I started having problems on boot-up where during the boot
> sequence the computer would freeze when it reached the NVRAM check.
> The screen will say
> DDR Frequency 400 Mhz
> Checking NVRAM..
> And then it stops booting up.
> If I turn off the power and reboot it then gets past that part on the
> second boot and shows the following instead:
> Overclocking Failed! Please enter Setup to
> re-configure your system.
> If I then press F1 to enter the Bios Setup menu and exit without
> changing anything the computer boots up fine.
> This problem now happens every time I boot my PC from having been
> powered off.
> At first I thought maybe the Ram chips were loose so I took them out
> and swapped the slots. That didn�t help.
> Now I am thinking it may be a BIOS setting, but I am not sure what I
> would need to reset in the BIOS to fix the problem.
> Any ideas would be kindly appreciated.
As a first step, I would change the CMOS battery. Next,
ascertain that the setting for PnP OS is "disable" in bios
setup.
