Upgrade winME to winXP problems
Yiannis
7
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi,
I have a Toshiba Satellite 1805-S203. It has a console
with play, stop, etc. buttons in the front pannel, which
work fine with the media player with winME. When I
upgraded to win XP professional, however, they didnt work
any more. None in Toshiba seems to know how to fix this.
What can I do?
Thank you.
Yiannis
G
Guest
Guest
Yiannis wrote:
> Hi,
> What can I do?
> Thank you.
> Yiannis
Obtain and install the WinXP-specific keyboard drivers from the
laptop's manufacturer. If Toshiba does not provide WinXP support and
drivers for that specific model, there's nothing more you can do to
get those proprietary keys working.
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on
having both at once. - RAH
G
Guest
Guest
> What can I do?
If Toshiba has no updates to make this work in XP, you may be SoL in XP.
<- Shenan ->
The information is provided "as is", it is suggested you research for
yourself before you take any advice - you are the one ultimately
responsible for your actions/problems/solutions. Know what you are
getting into before you jump in with both feet.
G
Guest
Guest
Toshiba Skins for Windows Media Player for Win98SE/WinXP/2000
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=131249&moid=1073833648&BV_SessionID=@@@@1883007964.1094423057@@@@&BV_EngineID=ccccadcmhelieilcgfkceghdgngdglj.0&ct=DL
Toshiba Software Upgrades 3
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_dtlViewDL.jsp?soid=107408&moid=1073833648&BV_SessionID=@@@@1883007964.1094423057@@@@&BV_EngineID=ccccadcmhelieilcgfkceghdgngdglj.0&ct=DL
Welcome to Toshiba Support!
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_home.jsp
Carey Frisch
Microsoft MVP
Windows XP - Shell/User
Be Smart! Protect Your PC!
http://www.microsoft.com/athome/security/protect/default.aspx
"Yiannis" wrote:
| Hi,
| What can I do?
| Thank you.
| Yiannis
