P5AD2-Premium: How can I disable the WLAN Radio part ?
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hello,
who can help me pls finding a solution to the following:
I want to have the WLAN drivers installed, but the Asus Tek Control Center
should start the WLAN Radio in Disabled Mode.
I was not able to find a solution to that yet.
The PC always starts with the WLAN Radio on and I have to disable the radio
manually using the mentioned program.
(Open the Asus WLAN Card Settings from the quickstart bar and clicking on
button "Disable Radio".)
I think there must be a setting anywhere to save the configuration with
"Disable Radio" as the default setting.
Any suggestions ?
Thanks.
Gerhard
P.S.
The software version I use id Asus Tek Control Center 2.2.0.3.
1 answer Last reply
More about p5ad2 premium disable wlan radio part
  1. I have the opposite (i hope i spell it right) problem.
    does nobody have any answer??
    (sorry for the bad english, but im dutch)
Asus Radio WLAN Motherboards
