G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
ok hers the problem:
I have just installed a new P5P800 mobo with a P4 530J 3.0GHz CPU,
3x256MB DDR333 RAM, along with a GeForce6600 256MB AGP8x
now that combination worked fine with my old mobo (ASRock 775S61), i
upgraded to the P5P800 to increase the performance of my games
i set it all up, turned it on and got nothin, turned out to be static
problems, i sorted all that out but now when i go to play games after
a matter of seconds my comp turns itself off, same thing for every
games i try to play, yet it works fine with everything else i try to
do
i got a new 650W power supply, thinking it was that, still nothing, i
got a 20pin to 24pin adapter thinking it was that, still the same, i
have tested all 3 sticks of ram and they all work fine
if any1 has any idea wot the problem could be then please post here or
get in touch with me on msn please
need any more info then please say, any ideas apriciated
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/ASUS-Probable-P5P800-problem-ftopict57909.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=292298
do
