Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
"" wrote:
> "chowda!" <cliverama@yahoo.co.uk> wrote in message
> news:1119888769.473064.156900@z14g2000cwz.googlegroups.com...
> > howdy, i am having an issue with this motherboard and xp not
> detecting
> > any usb devices i plug in to it. i have also tried plugging
> an external
> > usb card in to the mboard to no avail. the pc had been built
> by someone
> > else who has left the office and i have carried out a full
> format and
> > reinstalled xp, updated all drivers etc , gonna order
> another board
> > cause i cant seem to find a solution, any ideas??
> Did you check to see if the USB ports are enabled in the bios?
> Then Windows
> XP will install drivers and see anything that's pluged into
> the port.Or if
> you did enable the USB ports then maybe try downloading the
> latest bios and
> flash it. I think it is now version 1007. Create a dos boot
> disk flash per
> instructions on asus website but avoid the asus webupdate
> method.
> > Jimmy Martin wrote:
> >> Does anyone use their built in USB ports with any of these
> boards without
> >> any problems such as a failure in a USB device? Do you
> connect usb
> >> devices
> >> to the port while the computer is running? Any problems so
> far? I
> >> wondering
> >> if this is a problem that happens on some of these boards
> but not all of
> >> them? That is if there is a static charge on a usb cable
> that gets into
> >> the
> >> chip on the board it won't burn it out on every board. Or
> is it just a
> >> matter of being lucky and not getting a big enough static
> charge to do
> >> any
> >> damage?
> >> Jimbo
I am having the same problem. I have three identical compuers with
ASUS P4C800E Delux boards. All the usb were fine for about 6 months.
Now all of them have the same "drive not recognized" problem. If i
unplug the power and let the computer sit for a few hours, the problem
seems to go away for a few hours. Very disappointed!
Anyone has any ideas?
Posted using the
http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL:
http://www.hardwareforumz.com/ASUS-P4P800E-Deluxe-P4C800E-Deluxe-USB-port-latchup-problem-ftopict58056.html
Visit Topic URL to contact author (reg. req'd). Report abuse:
http://www.hardwareforumz.com/eform.php?p=296066
