Tom's Hardware > Forum > Motherboards & Memory > Asus > P4P800 Deluxe Voltage problems
Forum Motherboards & Memory : Asus - P4P800 Deluxe Voltage problems
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Here is my system
ASUS P4P800 Deluxe
Intel 3.2 GHz Processor
ATI Radeon 9600 XT
Creative Audigy 2 ZS
Thermaltake 450W PS
My issue is. Both the ASUS Probe and the BIOS Hardware Monitor says
that my +12V feed is dropping to around +10.5V
As you can imagine this is causing major issues on the system.
Video and memory errors being the first sign of this.
I've tested the powersupply and it producing a very nice +12.1V.
So I guess my question is,
Is this a known problem with the P4P800 Deluxe or could this still be
a power supply issue or something else?
Thanks
Doug
Sponsored Links
On Wed, 29 Jun 2005 17:47:45 GMT, Quantom Flux <nospam.qflux@hotmail.com> wrote:
>Here is my system
>ASUS P4P800 Deluxe
>ATI Radeon 9600 XT
>Thermaltake 450W PS
Did you test the power supply under load?
Not a known hassle. Try another power supply.
Reply to Anonymous
On Wed, 29 Jun 2005 22:17:08 GMT, Old Bugger <grumpy@mailinator.com>
>>Here is my system
>>ASUS P4P800 Deluxe
>>ATI Radeon 9600 XT
>>Thermaltake 450W PS
Sorry It's a 480W PS
Yeah tested it under load and with nothing running on it.
A different power supply gives the same results.
Reply to Anonymous
On Wed, 29 Jun 2005 22:56:02 GMT, Quantom Flux <nospam.qflux@hotmail.com> wrote:
It is a dud motherboard then.
Reply to Anonymous
I had to rma my same board due to power issues. I suspect some faulty
part was in production at the time. After the third video card I knew
something was wrong with the board. As a test, remove the agp card and
try a pci card and see what happens to the voltage. I believe the
problem lies in the agp circuit.
regards,
>>>Here is my system
>>>ASUS P4P800 Deluxe
>>>ATI Radeon 9600 XT
>>>Thermaltake 450W PS
Reply to Anonymous
On an odd note, the voltage of the system is back to normal, but the
video does goes out like it used to whenever the voltage would drop.
I suspect now that the voltage is staying fine unless I really push
the video on the board.
I'll test out your idea of using a PCI video card. I think I still
have one around her somewhere.
Thanks for the suggestion
>regards,
>>>>Here is my system
>>>>ASUS P4P800 Deluxe
>>>>ATI Radeon 9600 XT
>>>>Thermaltake 450W PS
Reply to Anonymous
There are 580 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
