G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.misc,microsoft.public.windowsxp.hardware,comp.os.linux.hardware (More info?)
Greetings. This has been a really odd problem.
I'm using a Belkin KVM switch (http://tinyurl.com/3ayms). The switch
works very well except for one problem: since it has a PS/2 mouse port,
I have to use a USB-to-PS/2 adapter to plug in to it.
Windows XP simply will not "see' this setup. It acts as though I have no
mouse. This is true, even when I've tried a large variety of different
mice, and even different connectors. And it's a WinXP problem, because
the other box I am using is Fedora Linux, and it has NO problems.
These are both "home-built" computers.
The video and keyboard have no problem except, when I'm in WinXP, if I
go about ten second or more without using the keyboard, the first
keystroke is "ignored" and causes a system beep. After that initial
keystroke, it's as if the system "woke up" and I have no problem using
the keyboard as long as I continue to type without long pauses.
Now the really weird thing is that my current setup is a Microsoft
cordless keyboard/mouse combo. You'd think with the "weirdness" of
having to connect the transmitter to the input ports on the KVM that it
might not work, but it works just great!
Again, since the mouse works just fine under Linux, it's not that the
mouse connection is the problem. It's strictly a "Windows XP thing."
Does anyone have any insights? Couldn't find a thing on the Belkin
website or doing a Google search.
Thanks in advance for your help.
