issue graphic and audio driver spresso 112
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
hello everybody
I encounter problems to install audio drivers (soundmax) on my spresso
(based onP4P800 865G)
none of the files qvqilqble on asus servers are working
could anybody help me to fix it?
in plus the graphic drivers are really unstable (even the last one from
asus or intel)?
has anybody already encountered the same problem?
thanks
jf
7 answers Last reply
More about issue graphic audio driver spresso
  1. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    In article <42ca6ff8$0$31218$626a14ce@news.free.fr>,
    strepto94@nospam_free.Fr wrote:
    > hello everybody
    > asus or intel)?
    > thanks
    > jf
    The download page for Spresso lists these two files (the download is
    split into two files):
    http://dlsvr02.asus.com/pub/ASUS/Barebone/terminator%202/t2-p/AD1888_part1.zip
    http://dlsvr02.asus.com/pub/ASUS/Barebone/terminator%202/t2-p/AD1888_part2.zip
    There is also an FTP directory, but the naming convention leaves a
    lot to be desired. I'm not even sure this is for the AD1888, because
    when you unzip the file, the created directory says "AD1980"...
    ftp://ftp.asus.com.tw/pub/ASUS/misc/audio/ad1888/AD1888_5150.zip (23MB)
    For a graphics driver, go to downloadfinder.intel.com .
    There are two kinds of drivers - the INFINST kind is used to
    install chipset drivers. That will give you proper enumeration
    of peripherals inside the chipset. A separate graphics driver
    is used for the Intel Extreme Graphics. Finally, install a
    recent copy of Microsoft DirectX
    Use this one to get INFINST chipset driver.
    http://downloadfinder.intel.com/scripts-df-external/Product_Filter.aspx?ProductID=1049&lang=eng
    This link will give you a graphics driver for 865G (WIN2K_XP1413)
    http://downloadfinder.intel.com/scripts-df-external/Product_Filter.aspx?ProductID=1044&lang=eng
    Use this to find DirectX 9.0c
    http://www.microsoft.com/windows/directx/default.aspx
    HTH,
    Paul
  2. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    thanks I will try these files tonight
    but in any case the ftp link you mentioned provides a compressed that is
    extacted whereas the archive in two parts doesn'allow extraction of WDM
    drivers
    many thanks
    jfm
  3. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    even with the new audio package no way to install drivers (they can be
    extracted) but unusable
    I don't know what to do???
    jf
  4. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    In article <42CD18D7.7030005@nospam_free.Fr>, strepto94@nospam_free.Fr wrote:
    > jf
    By unusable, what response are you getting when you try to use the
    installer ? Any error messages (please include the _exact_ text) ?
    Is is possible this is a localization problem ? Asus doesn't do
    that good a job of supporting OSes, when the language is not English.
    Generally, that happens when Asus writes the software, and I hope
    that this Analog Devices driver is not affected by localization issues.
    If you look in the folder created by unzipping the package, there
    is a directory called "SMAXWDM", and below it "W2K_XP". In there
    is a file called "smwdmVI3.inf". It lists Device information, and
    in order for the low level driver to install, the Ven/Dev/Subsys/Ver
    must match.
    For example, on my P4C800-E with AD1985, these values would be
    8086/24D5/80F31043/02
    The 8086 means Intel
    The 24D5 refers to ICH5 Southbridge.
    The 1043 is the subsystem ID belonging to Asus
    The 80F3 could be a unique identifier for the motherboard P4C800-E
    The 02 version, I haven't a clue.
    Get a copy of Everest "Home Edition" from this site. It is a
    utility similar to Sisoft Sandra. Install it, then use the
    Everest program:
    http://www.lavalys.com
    If you look in the Devices section, in Windows Devices, you should
    see an entry for the Sound chip. That is where you can look up
    the Vendor/Device/Subsystem/Version of the chip. In Physical
    Devices, there should be an entry for Bus 0, Device 31, Function 5,
    and that is the AC97 part of the Southbridge. While knowing the
    Southbridge type is important to the driver, you will not find
    any info in the smwdmVI3.inf file that corresponds to those numbers.
    The naming convention of the .inf file is important, as it gives
    a clue as to which Southbridge family is supported. In the
    example we are using here, smwdmVI3.inf, the "VI" part means the
    driver handles VIA chipsets. There are other driver versions
    that contain smwdmCH5.inf. Since the 5150 driver has a smwdmVI3.inf
    file, but it has twice as many entries as before, it is possible
    the naming convention is no longer accurate, and the 5150 driver
    support both VIA and Intel Southbridges. So, in the past, finding
    the "VI" part would mean we had the wrong driver, I don't think
    that is the problem in this case.
    I really don't understand too much about drivers and installation.
    What I do know, is a driver won't install, if the Ven/Dev/Subsys/Ver
    coming from the hardware, doesn't match a line in that .inf file.
    So, using Everest, see if you can figure out the declaration of
    your sound chip, and whether it matches any of the .inf files of
    the drivers you current possess. The Subsys field is
    "soft programmable", and the Asus BIOS writes 80F31043 into
    two registers inside the sound chip. That is how the Sound Chip
    can identify that it is living on a particular motherboard design,
    and it also means that Analog Devices must add at least one
    line of code to the .INF file for every new motherboard design
    with their sound chip on it.
    HTH,
    Paul
  5. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    > jf
    Also, enter the BIOS and make sure
    OnBoard AC'97 Audio [Auto]
    is set. The setting should not be [Disabled]. Some
    Asus BIOS will disable AC'97 if another Sound Device
    is detected, so that is another possible reason as
    for why the AD1888 cannot be detected. See if the
    Device Manager lists any other sound devices.
    The AD1888 chip could also be defective, but it is
    too soon to jump to conclusions.
    Here is another driver to try:
    ftp://ftp.asus.com.tw/pub/asus/mb/sock478/P4P800S-X/AD1888.zip
    I had trouble with AD1888_part1.zip and AD1888_part2.zip.
    I got AD1888.part1.rar (10000000 bytes)
    AD1888.part2.rar ( 5846356 bytes)
    I was able to unrar the results (Asus is supposed to make one
    of the files a .exe, so the result will be self extracting).
    But the directory that results (AD1888) causes my PC to freeze
    if I explore it. So something is wrong with those files...
    HTH,
    Paul
  6. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    thank you so much
    i will try this tonight
    I knew everest but I didn't think to use it for that kind of purpose
    great
    in fact I tried to install with and without Asus auto installer
    but I didn't think to check the pathway, now that you indicated me which
    file to check.....
    I think this time will be the good one
    many thanks
    jf
  7. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    bios was ok
    finally the last file you indicated works
    so many thanks
    jf
Asus Drivers Audio Motherboards
