Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I have a 802.11 wireless network at my home using 3 PCs with a Netgear MR814
wireless router. Yesterday, one of my PC could not obtain dynamic IP adress
using DHCP. IP address and subnet mask are 0.0.0.0., and when I try to
repair (renew) the connection, I get the error message that the repair
operation failed. When I try to use IPconfig utility to renew IP address, I
get the following message:
"The DHCP client has obtained an IP address that is already in use on the
network. The local interface will be disabled until the DHCP client can
obtain a new IP address."
No other PC has this problem. I am temporarily bypassing this problem by
manually assigning an IP address to this PC. Can someone tell me why I am
getting this conflict and how do I resolve the issue? Thanks
Sponsored Links
Check your DHCP settings in your router?
Joseph
"hanu" <hanu@discussions.microsoft.com> wrote in message
news:6D704DC7-0918-4187-B2D3-8CD93B1589E5@microsoft.com...
MR814
adress
I
Reply to Anonymous
- 0 +
Rather odd you received a 0.0.0.0 address other than a
169.x.x.x .Double check your PC settings that the client
is setup to obtain an IP address.
>-----Original Message-----
when I try to
that the repair
renew IP address, I
DHCP client can
this problem by
tell me why I am
Thanks
Reply to jeff
"Jeff" <anonymous@discussions.microsoft.com> wrote in message
news:234201c50b24$5eaa3b70$a601280a@phx.gbl...
This is the behavior when a duplicate IP is detected. Windows removes the
address assignment (0.0.0.0). It doesn't try to pull another address via
DHCP, alternate config, or automatic. User intervention is required.
Reply to Anonymous
>MR814
> adress
> address, I
> am
The error means exactly what it says.
Since there are only 3 PCs and the router:
1. Unplug the router
2. Shutdown the PCs
3. Restore power to the router
4. Restore power to the PC with the conflict. It should now be able to
pull the address from the router.
5. Restore power to the other PCs. If one of them had an old lease that
was causing the conflict, the renewal request will be denied and it will be
able to pull a new IP.
Reply to Anonymous
Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > DHCP problem
There are 1177 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 16:28 bilbat won the Motherboards badge
  • 01:00 jayhsyn won the Freshman badge
  • 01:00 nesta13 won the Freshman badge
  • 01:00 petar won the Freshman badge
  • 01:00 sinsear won the Freshman badge
  • 01:00 UnawareAtol won the Uniformed badge
  • 01:00 buryaku won the Uniformed badge
  • 01:00 Redras0324 won the Uniformed badge
  • 01:00 dvdmania won the Uniformed badge
  • 01:00 ugotomega won the Uniformed badge
