G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hello,
I'm using XP Pro with SP2
I bought a USB 2.0 IDE interface to atempt to rescue some info from a
damaged disk. I plugged the HD into the interface and with the
correct HD jumper settings the HD is recognised as
USB Mass Storage Device
then
Disk Drive
Device manager shows the disk drive as USB 2.0 Storage Device USB
Device
all items in device manager are shown as working.
If the jumper settings on the HD are not as instructed in the breakout
box instructions the device does not get recognised.
The final tray-bubble is Your New Hardware is Installed and Ready To
Use.
How can I actually get to this drive - is there a manual config I can
do to assign a drive letter?
Many thanks
Rob
Hello,
then
Disk Drive
Device
Use.
Many thanks
Rob
