Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Howdy group,
I have a P4C800-ED mobo and a few weeks ago I installed a I/O panel
that included several USB ports, readers for various digicards, etc.
Everything worked OK for about a week and then the card readers
failed. WinXP says ... "Unknown Device". The USB ports continued to
work OK.
I took it back & got my money back. I've now installed a FRONTX I/O
panel that includes USB, 1394, etc. Working just fine.
I also purchased a external USB Card Reader. WinXP detected the card
reader OK and Windows Explorer showed several "Removable Drives". I
then "stopped" the reader & removed it without any obvious problems.
The next time I tried to use the card reader ... it died, "Unknown
Device" AGAIN!!! Also get "Unknown Device" when I try plugging the
card reader into my sons laptop.
MY USB HD, digicam & scanner all work OK in the same USB ports. The
FRONTX USB ports are connected to USB56 header on the mobo.
Maybe I've just be very unlucky with 2 card readers failing. However,
I was wondering whether it's possible that the mobo is supplying to
much power or there's some other obscure reason for the failures.
Any ideas, suggestions or recommendations?
Thanks very muchly
Barry...
Howdy group,
work OK.
Thanks very muchly
Barry...
