Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I bought this mobo about 6months ago and have a three year warranty
with Asus. My chip fan has been making alot of bad sounds and is
struggling to run. It starts and stops at 10second intervals sometimes
even less...I was wondering what the best thing to do would be..Either
send the mobo back and get a new one or get a new chip fan..what would
u suggest?
Aiden
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/ASUS [...] 59793.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=302441
> u suggest?
That was a problem with the early versions of that board. Contact
ASUS and they will send you a quieter replacement.
Kevin Chalker, Owner (KC COMPUTERS)
E-mail: kc@kc-computers.com Web: www.kc-computers.com
Internet dealer since 1991!!! See WWW.RESELLERRATINGS.COM!!!
Known and very well unofficially documented flaw with the motherboard.
Buying a Zalman NB47J chipset passive heatsink will do the track. I had to
do this and so did many others that I know who own this board.
If you don't want to deal with the passive heatsink, I think you can still
call ASUS and they'll send you another fan although I don't know if it's the
same one that is breaking down for everyone.
Nocturnal
"nexx" <UseLinkToEmail@HardwareForumz.com> wrote in message
news:7_302441_c8fe41e982dc8313fde8bfbdcba767d8@hardwareforumz.com...
> u suggest?
> Aiden
> request
> Topic URL:
> warranty
> and is
> sometimes
> be..Either
> fan..what would
> > u suggest?
> Contact
Thank You
Its in the mail ^_^
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=303332
I put the Zalman cooler on recently as well. I got my board the first week
of January and I couldn't take the noise any more. It actually is 1-2
degrees cooler than the fan. Never goes above 40-41 deg after 4 days
straight of F@H. I realize that probably doesn't drive the chipset, but the
cpu never went above 38 degrees with the 7700-cu cooler. a great combo. BTW
I live in Las Vegas and the case temp is normally 33-34 degrees.
Tom
"Nocturnal" <nocturnal@anonymous.com> wrote in message
news:9RBIe.2856$5g.142@tornado.socal.rr.com...
> to do this and so did many others that I know who own this board.
> the same one that is breaking down for everyone.
> Nocturnal
>> u suggest?
>> Aiden
>> request
>> Topic URL:
Which Zalman cooler did you install ?
I have a passive one by Zalman, and it is
quite warm to the touch.
How do you read the temperature of
the chipset. I do not see any data in
PC Probe.
"tawpgk" <tawpgk@nospammers.net> a écrit dans le message de news:
JwOIe.50983$Eo.12115@fed1read04...
> Tom
>> still call ASUS and they'll send you another fan although I don't know if
>> it's the same one that is breaking down for everyone.
>> Nocturnal
>>> u suggest?
>>> Aiden
>>> request
>>> Topic URL:
I have the same HS as you the NB47J. I am taking the Motherboard temperature
as the nForce4 chip temperature. Is that not correct?
Tom
"Natéag" <gaetanfo@videotron.ca> wrote in message
news:RDPIe.19762$U22.675905@weber.videotron.net...
> PC Probe.
>>the cpu never went above 38 degrees with the 7700-cu cooler. a great
>>combo. BTW I live in Las Vegas and the case temp is normally 33-34
>>degrees.
>> Tom
>>> if it's the same one that is breaking down for everyone.
>>> Nocturnal
>>>> u suggest?
>>>> Aiden
>>>> request
>>>> Topic URL:
Right now the with F@H running the CPUis at 38 and the motherboard reading
is at 39. when I touch the top fins of the NB47-j, they are barely warm. The
base is fairly warm but not too hot to touch.
Tom
> PC Probe.
>>degrees.
>> Tom
>>> Nocturnal
>>>> u suggest?
>>>> Aiden
>>>> request
>>>> Topic URL:
On Fri, 5 Aug 2005 15:01:00 -0700, "tawpgk" <tawpgk@nospammers.net>
After many questions and replies on many forums besides this one, I
believe that you are, indeed, correct. The "motherboard" or "system"
temperature is always the hottest one reported on this series of
boards. I think that logic tells you that this sensor must be in or
near the nForce chipset.
There have been posts from a few A8N-SLI Premium owners whose choice
of case forced them to mount the board upside down. In that case the
heatpipe cooling of the chipset fails, and the chipset becomes
terribly hot. These users reported "system" temps of over 60°C.
Ron
That's because the Premium uses a heatpipe setup which has to be mounted in
a certain orientation, if you put it upside down, it traps the heat at the
chipset instead of transporting it to the heatsink
"milleron" <millerdot90@SPAMlessosu.edu> wrote in message
news:jqt9f11ta6eobgauo74njrt0hmfestr1a7@4ax.com...
>>temperature
> Ron
> The base is fairly warm but not too hot to touch.
I considered the same passive heatsink, but it does not cover the whole
chip, as it is rectangular. Should one just ignore this?
> one, I
> "system"
> of
> in or
> choice
> case the
> 60°C.
> Ron
Well My motherboard temperature is at a steady 40C. My fan hasnt been
working for months and the temp has never increased.
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=303796
On Mon, 8 Aug 2005 13:04:13 +0200, "LD" <answer.tothe@group.invalid>
I've read dozens of posts from users who installed this Zalman
heatsink on A8N boards, and I've never seen one reporting any
problems, at all.
Ron
The actual die on the Nforce chip that mates to the heatsink is actually
rather small. Its not an issue.
"LD" <answer.tothe@group.invalid> wrote in message
news:42f73a17$0$94500$edfadb0f@dread11.news.tele.dk...
>> reading
It does cover the whole chip, I just did one last week. A bit fiddly to get
the pegs to line up with the holes but works perfectly.
Mark
I installed the Zalman on my chipset before I even
installed the motherboard. Got it running today and
that thing is hot to the touch.
An earlier poster said he has been running his without
the fan running so I guess it's not gonna hurt it.
The stock HSF doesn't have much of a heatsink.
Larry
"Mark" <no.mail@reply.here> wrote in message
news:memo.20050810183102.1220A@nowhere.free-online.co.uk...
> get
> Mark
I've been using a coolermaster heatsink only, it's just like the zalman.
It's been 100% stable for 6 months now.
"Larry" <k5zh@sox.net> wrote in message news:3ntKe.7$Pl1.1@okepread02...
> Larry
>> get
>> Mark
I installed my Zalman when I built the motherboard. No fan. I've just touched
it now, cold, not remotely warm!
I have a large 120mm inlet fan blowing into the case about 6 inches away from
the chipset+heatsink.
Mark
On Thu, 11 Aug 2005 19:50 +0100 (BST), no.mail@reply.here (Mark)
>Mark
Any thoughts as to how different users could get such widely varying
results, all the way from "that thing is hot" to "cold" using the same
heatsink?
Ron
> heatsink?
That is weird to me also Ron. My Zalman heat sink is too hot
to touch for more than a second. Mark has a good airflow to
his. I have an 80mm fan blowing past my hard drive before it
gets to the Zalman. I've only had it running one day and have
not had any crashes yet.
"> Any thoughts as to how different users could get such widely varying
> heatsink?
I just read a review on Newegg that Asus has a new fan
that will fix the problem.
> heatsink?
Other than I have a 120mm YSTECH fan blowing over it.
This model provides probably one of the biggest air flows of any computer fan
I know, YS-TECH FD1238 120mm fan 2800rpm, 125cfm 40.5dBA £11.69
overclockers.co.uk.
Mark
On Sat, 6 Aug 2005 23:55:04 -0400, "Jason" <ae2wolfman@bellsouth.net>
Yes, we know why it gets hot when mounted upside down. This scenario
was posted here as evidence that the temp sensor that's reported as
"motherboard" or "system" is actually measuring the chipset
temperature.
>>>temperature
>> Ron
Ron
There are 1247 identified and unidentified users. To see the list of identified users, Click here.
