Archived from groups: alt.comp.periphs.mainboard.asus,alt.comp.periphs.mainboards.asus,asus.support.english.mainboard (More info?)
I have had an A7V333 for a few years now. For the first time since I got it,
I have a USB 2.0 device. I plugged it in and installed it, and Windows (XP
Professional SP2) popped up a message saying that the device would be faster
if it was in a port that supported it; in other words suggesting that this
was not a USB 2.0 port (but it definitely is). I got out the ASUS manual and
found there's a USB_EN jumper, but this was already enabled. I then thought
that perhaps it is because I need drivers. I tried the drivers that came on
the CD, but this stopped the ports working altogether, probably because they
were pre-SP1. I tried drivers from the ASUS site, but no luck, and also from
the VIA site. I now have driver v2.52 I think (which I found on ASUS's FTP
service in the A7V333 folder). This seems to work the best; I now have "USB
2.0 Root Hub" and "VIA USB Enhanced Host Controller" in the Device Manager,
yet I still get the same popup when I plug the device into a USB 2.0 port,
so apart from the entries I now have, I'm no better off!
I've had a good search of Google Groups today and found many many similar
problems, but these are usually before SP1 was available. Nonetheless, I've
tried almost everything I can find to no avail.
Can anyone help?
Many thanks in advance.
Can anyone help?
