Archived from groups: microsoft.public.windowsxp.hardware (More info?)
My microphone doesn't work anymore! The last time I used
it, with windows recorder was a few months ago, and it
worked perfectly. Now, it doesn't record or input any
sound at all. I have checked all of the volume controls,
both playback and record, making sure all mutes are
unchecked and all volume sliders are turned up. The mic
is plugged into the correct input on the soundcard. And
the mic works on other equipment. Now, I just installed
Windows XP SP-2 last week, and all seemed to be fine,
HOWVER:
When I go into the record control from the sounds and
audio properties window (of the "adjust audio properties"
button from the speaker in the desktop tray, lower
right), something interesting happens. If "Microphone" is
checked as the recording device, nothing happens. BUT, if
I check ANYTHING else, such as line-in, wave, CD, etc.
suddenly the mic starts working, and I can hear it
through my desktop speakers! However, it won't record
using windows sound recorder or any other program. I
noticed that the Record Control window
under "help" "about" says that the version was changed
and updated for SP-2. Is this my problem? Thanks in
advance for any help!
HOWVER:
