Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
It was probably half of a 1 gig set.
"DB" <db002a3121(NOSPAM)@blueyonder.co.uk> wrote in message
news
D7Le.87736$G8.18245@text.news.blueyonder.co.uk...
> Paul, i downloaded and ran CPUID and it confirmed the chip as 512
> too......( I bought it from a guy on ebay...OOOh dear...)
> I've tried in all of the 3 slots and i get the same reading..of 512..
> according to the label its a 1 gig board...
> stuck now..
> Dave
> thanks again..
> "Paul" <nospam@needed.com> wrote in message
> news:nospam-1208051450590001@192.168.1.178...
>> In article <ZX4Le.87617$G8.75747@text.news.blueyonder.co.uk>, "DB"
>> <db002a3121(NOSPAM)@blueyonder.co.uk> wrote:
>>> er no I didnt.....how do I do that Charles, previously I has 256 but now
>>> shows 512
>>> Dave - thanks
>>> "Charles Sapp" <crsapp@insightbb.com> wrote in message
>>> news:rU4Le.243617$x96.12154@attbi_s72...
>>> > Did you clear ESCD (BIOS) before rebooting after new RAM installation
>>> > news:sO3Le.87578$G8.50395@text.news.blueyonder.co.uk...
>>> >> I've just installed a 1 gig ddr memory card into my ASUS A7V8X-X
>>> >> motherboard but when i boot up and look at the properties on my PC it
>>> >> is
>>> >> only showing 512 meg, the same amount is displayed when I lok at the
>>> >> BIOS.
>>> >> Hmmm,I thought it would pick it straight up.
>>> >> Any clues ?
>>> >> Thanks
>>> >> Dave
>> He is talking about the CLRTC jumper. In your manual, go to section
>> 1.11 "Jumpers". Item #3 in that section tells you how to clear the
>> CMOS. Clearing the CMOS will likely cause the onboard clock to be
>> reset, and you'll have to re-enter BIOS settings. The most important
>> part of the procedure, is to unplug the computer, to protect the
>> ORing diode in the standby power circuit.
>> If you can boot the computer, I would start with a copy of CPUZ from
>> www.cpuid.com . I believe CPUZ has the ability to dump the contents
>> of the SPD chip on the DIMM. Perhaps it will tell you something about
>> the design of the DIMM.
>> I would also test the new DIMM by itself, removing the old memory
>> DIMM. That might make it easier to figure out what the computer
>> sees or doesn't see.
>> Your manual says you may use 3*1GB DIMMs (with some restrictions
>> on memory clock rate, as three double sided DIMMs is a heavy
>> capacitive load to drive). The KT400 will have some number of
>> memory address bits, and a certain number of row and column
>> address bits are needed to address the whole memory.
>> When a chipset says it is limited to a 1GB stick, that might
>> mean it could only deal with 64Mx8 chips. It might only have
>> enough memory address bits to do that. If the DIMM had 128Mx4
>> chips on it, that might mean the DIMM needs one more memory
>> address bit than the chipset has to offer. The consequence of
>> using (16) 128Mx4 chips, might be that only 512MB can be seen.
>> A construction more likely to work is (16) 64Mx8 chips, which
>> logically is two "ranks" of memory. Those DIMMs tend to be
>> more expensive than other potential constructions.
>> So, have a look at the SPD info from the DIMM, or if your
>> memory vendor had a shred of honesty, there might have
>> been some info suitable for warning you of the potential
>> for problems.
>> For example, here is an advert from Pricewatch, "coded" to
>> indicate the potential for trouble. When a vendor starts
>> naming "compatible" chipsets, it implies something funny
>> about the RAM.
http://www.pricewatch.com/prc.aspx?i=33&a=5025
>> "MemoryPRO - D400-1284-1G
>> MemoryPRO High Density 1GB DDR PC3200 DDR400 184-Pin DIMM
>> Memory for KT400 KT600 & SIS 645 648 648FX 746FX Chipsets
>> & more."
>> The "high density" implies the deeper addressing RAM chips,
>> of 128M by 4 bits wide memory chips ("high density" is not
>> a precise term, so I treat this as a hint). Their part number
>> also hints at that. The naming of the chipsets means at the
>> least, that the DIMM places more capacitive load than normal
>> on the memory bus, and that list of chipsets can probably
>> drive at least one DIMM. You might not be able to drive 3
>> of these, at full speed. Since datasheets for the above named
>> chipsets are not likely to be available, it is hard to say
>> more about whether the row/column addressing bits are
>> sufficient to address 128 million locations on a single DIMM
>> rank. (If the product support 2GB DIMMs, then the answer would
>> be yes.)
>> See if you can swap for a 16 chip 64Mx8 chip type DIMM. Your
>> vendor will need more cash for the transaction. It
>> will have normal bus loading, and might be fully
>> addressable by your KT400 Northbridge.
>> You can see the difference in price here. At one time, vendors
>> like this gave no warning whatsoever, about the fitness of
>> their products, and I guess a stready stream of returns
>> and fights about restocking fees, is improving the quality of
>> the adverts.
http://www.portatech.com/catalog/memory.asp?ID=285
>> Just some guesses,
>> Paul
