Tom's Hardware Forums » Motherboards & Memory » Asus » A8N-SLI Deluxe Not Running Correct Speed
Add a reply
 Word :   Username :
Bottom
Author
 Thread : A8N-SLI Deluxe Not Running Correct Speed
Profile: stranger
More Information
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I just set this up this week and noticed it's not very fast.
System Properties reports 1000 MHz. CPU-Z reports
Core Speed 1005 MHz and Multiplier X 5.0
BIOS reports correctly 2000 MHz and CPU frequency
200 MHz.
I have not tried to overclock and left the BIOS alone
in that regard. Overclock Profile in BIOS - STANDARD
or AUTO makes no difference.
What am I missing?
Larry
A8N-SLI Deluxe
Venice 3200+
G Force 6600GT
1 Gig Corsair XMS PC 3200
Hitachi 250 Gig SATA II
480 Watt Thermaltake
Windows XP SP2
BIOS 1011
Related Pr oduct
More Information
"Larry" <k5zh@sox.net> wrote in message
news:idbLe.7276$Pl1.4659@okepread02...
> 200 MHz.
> What am I missing?
> Larry
> A8N-SLI Deluxe
> Venice 3200+
> G Force 6600GT
> Windows XP SP2
> BIOS 1011
Do you have cool & quiet enabled in the BIOS?
Profile: stranger
More Information
Yes, and I have the software installed in Windows.
I considered this but did not know if this affected
what Windows would report. I didn't think it would
reduce the cpu by half.
More Information
news:HVbLe.7278$Pl1.3784@okepread02...
Disable it in the BIOS.
That is your problem.
My 3500+ drops to 1000MHz using only 1.075 volts when I enable C&Q in the
BIOS.
Profile: stranger
More Information
"Pete M Williams" <postmaster@localhost> wrote in message > Disable it in
the BIOS.
> BIOS.
I don't know anything about this C & Q but if it's not going to cause a
problem I might just keep it running. I was watching CPU-Z while
launching an application and the speed & multiplier jumped up
immediately to the correct speed then dropped back to 1000 MHz.
Have there been any posts about it causing problems?
More Information
news:7NdLe.7279$Pl1.2845@okepread02...
> the BIOS.
>> BIOS.
All C&Q does is underclock your CPU (only when the CPU is idle) by dropping
the volts and the multiplier.
Because the CPU gets less volts, its temperature is a lot less so the CPU
fan can run slower and quieter.
If you do a task that requires lots of processing power, then C&Q ups both
the volts and the multiplier to normal.
The only people that seem to have issues with C&Q are overclockers.
So unless you are overclocking your system C&Q "should" do no harm
Add a reply
Google Ads
News
CeBIT 2008: Three new ASUS Motherboards for AMD CPUs
Published on March 05, 2008
ASUS is introducing three new motherboards for the AMD platform at this year's CeBIT - the M3N-HT Deluxe/Mempipe, the M3A32-MVP Deluxe/WiFi-AP and the Crosshair II Formula. All three boards use socket AM2+. Read more
Biostar unveils Nvidia nForce 500 series motherboards for AM2 platform
Published on May 23, 2006
Biostar Microtech on May 23 introduced its new T-series motherboards supporting AMD's AM2 platform and nForce 500 series chipsets, the TForce 590 SLI Deluxe and TForce 570 U Deluxe. Read more
Biostar unveils Intel P965 motherboard
Published on June 08, 2006
Biostar Microtech International on June 7 announced its new T-series LGA-775 motherboard with the Intel P965 Express chipset. Read more
Gigabyte and MSI launch motherboards for AM2 platform
Published on May 24, 2006
Micro-Star International (MSI) and Gigabyte Technology today introduced motherboards that support AMD's AM2 platform and the Nvidia nForce 500 series chipsets, while Biostar announced its TForce 590 SLI Deluxe and TForce 570 U Deluxe motherboards for the new platform. Read more
Latest Reviews & Articles
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
SLI & Centrino 2: Gaming Laptops Battle
Published on September 24, 2008
Take four gaming laptops. Arm two of them with SLI and make the others Centrino 2-compatible. You're looking at a high-end collection of the latest mobile technology battling it out for benchmark supremacy and your hard-earned dollars. Read more
1,000 GB: Three Samsung TB Drives
Published on September 23, 2008
Storage vendors split the desktop hard drive market into performance, mainstream, and energy-efficient products. We looked at Samsung’s Spinpoint F, the RAID version and the EcoGreen F to discover how a 1,000 GB drive differs from another. Read more
