P4B533 weird problem & a question (long-ish)
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have a weird problem & a question.
First off, how about this for a weird one?
I have a P4B533 with 1004 BIOS with a P4 2gig (Northwood) which has worked
flawlessly for 3 years. I recently upgraded to Windows XP (clean install) and
decided to start using USB2 devices (Maxtor OneTouch II, USB2 memory stick etc.)
and so I enabled the USB2 controller in CMOS and connected everything up i.e. a
D-Link 7-port USB2 hub for the USB2 devices and the Belkin 15-in-1 card reader &
3-port USB2 hub for the USB1.1 devices.
Every time I power on the PC from cold, a hardware failure message comes up in
the BIOS boot screen. If I power off then back on again about 5 secs later, the
message doesn't appear.
The hardware failure message is occurring because the CPU VCORE voltage setting
and actual VCORE voltage do not agree. FORTUNATELY, I decided to leave the
OVER_VOLT jumper on the motherboard set on disable so the ACTUAL voltage
(according to the hardware monitor) was just 1.53 volts as opposed to the CPU
VCORE setting in the ADVANCED menu saying 1.85V (eep!).
To cut a long saga of detective work short, the problem is being caused by (if
you can believe this 'cos I can't) the Belkin 15-in-1 card reader & 3-port USB2
hub!! EVERY time I power on from cold - even with no USB devices connected to
the hub the fault occurs and then clears if I power off & immediately back on
again. If I unplug the Belkin unit the fault doesn't happen at all - even on
cold power-up. I've tried the Belkin unit in three different motherboard USB
ports & the same thing happens in every port! The D-Link 7-port USB2 hub OTOH
seems fine. Anyone any ideas - apart from ditching the Belkin card reader or
connecting it only when needed?
The question: all my USB 1.1 devices are using the USB ports on the Belkin card
reader. I have decided to buy another D-Link 7-port USB2 hub ('cos I know they
work OK) & transfer the USB 1.1 devices I have from the Belkin unit to the new
D-Link hub when it arrives (to ensure the USB2 devices I have don't get slowed
down by mixing USB2 & USB1.1 devices on the same hub). Will I have to reinstall
the broadband modem & printer drivers that are currently using the Belkin ports
or do I just plug them into the new hub when it arrives & Plug-N-Pray will auto-
reallocate the existing drivers in Device Manager?
Thanks a lot... sorry it's rather long!
Nigel
8 answers Last reply
More about p4b533 weird problem question long
  1. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    "Nigel Morgan" <nigel@wycombe.demon.co.uk> wrote in message
    news:dg81g1p9i0f4kjqo5mj9k0k42q2t4jf97b@4ax.com...
    and
    etc.)
    i.e. a
    reader &
    up in
    later, the
    setting
    CPU
    (if
    USB2
    to
    on
    on
    USB
    OTOH
    or
    card
    they
    new
    slowed
    reinstall
    ports
    auto-
    > Nigel
    There seem to be a lot of USB 2.0 problems with this motherboard. I wonder
    if adding a PCI USB 2.0 card would help?
  2. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    I would be emailing belkin about that one...My son's p4b533 runs usb2
    just fine, but he is not using any hubs...
    The ports where you plug in those 2 devices, are they the mobo ports
    that are hardwired or did you set the pins for say, the front or extra
    rear panel ? It could also be that the specific device needs more
    juice, in that case, it can be adjusted in device manager...
    Of course, maybe your power supply is being taxed? But the tests on
    other boards would indicate no...
    Regards,
    On Mon, 15 Aug 2005 15:41:56 +0100, Nigel Morgan
    >Nigel
  3. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    On Tue, 16 Aug 2005 04:32:26 GMT, timmy <bs@aol.com> inspired by Deep Thought
    wrote:
    Thanks both for the replies.
    Timmy, 2 points: 1) I'll be surprised if it's the power supply as it's a brand
    new ANTEC TruePower 550 (i.e. 550 watts), but then again, one never knows!
    2) I'm using the four USB ports on the rear of the motherboard.
    I've just had another idea: I'll try powering up the PC from cold with the
    Belkin card reader unpowered (i.e. leaving the small power supply module
    unplugged) & then when the CMOS has finished initialising (I have a boot
    password set) I'll plug it in. I'll let you know what happens.
    John: I've just looked in the manual for the P4B533 & I'm wondering if some of
    the problems are being caused by the (AFAICT hard-wired) PCI INT mappings.
    According to page 2.14 of the manual, INTA is shared between the AGP slot (which
    I'm using) and Onboard USB controller HC0 which I assume corresponds to USB
    ports 1 & 2 next to the audio connectors. Could this be the reason? Thankfully
    I'm only using 2 PCI cards & I used slots 2 & 4 which do not have shared INT's!
    Thanks,
    Nigel
  4. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    news:12c3g15lbfhfc3bfq9j7sqobm5v9ej7c1h@4ax.com...
    Thought
    brand
    some of
    (which
    USB
    Thankfully
    INT's!
    > Thanks,
    > Nigel
    Do a search in Google groups on P4B533 and USB 2.0 and you'll find a
    bucketload of people with USB 2.0 problems. I suspect the motherboard is
    hardware defective. Some have suggested that turned off onboard LAN can fix
    the problem. Others just bought a cheap USB 2.0 PCI card. It's annoying, but
    apart from this issue it was a very good motherboard.
    I've read a LOT
  5. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    On Wed, 17 Aug 2005 00:04:34 +1000, "John" <knight_js.nospam@yahoo.com> inspired
    by Deep Thought wrote:
    Thanks again John, it does look like there are issues with this board & USB2. I
    was blissfully unuaware of these because up to now I only used USB1.1. Why the
    Belkin hub/card reader doesn't want to play ball & the D-Link hub works OK beats
    me!
    I'm leaning towards your thinking as my trusty old D-Link USB1.1 hub has
    suddenly stopped working with this board now I've switched USB2 on.
    Oh, BTW, what USB2 Reference voltage should be set in the CMOS? I've left it
    with the default of Medium.
    Cheers,
    Nigel
    >I've read a LOT
  6. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    By the way, there are at least two versions of the motherboard. I wonder if
    the later version has the USB 2.0 problem fixed. It was the later version
    that Asus tested when investigating this problem, and claimed not to be able
    to reproduce it.
    Sorry. I don't know the answer to the voltage question.
    news:u1t3g15b1m6u4i1co5msf8poh9atnuh0mt@4ax.com...
    inspired
    USB2. I
    Why the
    beats
    > me!
    it
    > Cheers,
    > Nigel
    fix
    but
    > >I've read a LOT
  7. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    medium on the one here, I'll check the pcb version...
    On Wed, 17 Aug 2005 01:21:56 +1000, "John"
    >to reproduce it.
    >inspired
    >USB2. I
    >Why the
    >beats
    >> me!
    >it
    >> Cheers,
    >> Nigel
    >fix
    >but
    >> >I've read a LOT
  8. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    On Tue, 16 Aug 2005 15:17:58 +0100, Nigel Morgan <nigel@wycombe.demon.co.uk>
    inspired by Deep Thought wrote:
    Thanks Timmy, in that case I'll leave mine set to Medium as well.
    Well I've found a way round the problem purely by accident! I discovered that
    by forgetting on one occasion to switch on the external power supply unit for
    the Belkin hub/card reader before I powered up the PC, that the problem didn't
    occur! So what I do now is power up the PC with the Belkin hub PSU switched off,
    wait until the CMOS has finished initialising, switch the Belkin PSU on and then
    enter my boot password to start the OS loading.
    Still weird though!
    Nigel
    >me!
    >Cheers,
    >Nigel
    >>I've read a LOT
    Aagh! Every time I learn something new... it pushes something old out of my brain!
Asus Devices Motherboards
