Tom's Hardware Forums » Motherboards & Memory » Asus » P4C800E Deluxe Bio 1023 Problem
Add a reply
 Word :   Username :
Bottom
Author
 Thread : P4C800E Deluxe Bio 1023 Problem
More Information
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Flushed to 1023 and the system will hang during POST with "CPU overclocking
failed" message even if it was not overclocked (P4 3.2 G). Press F2 will
boot to Windows XP but the LAN will not work (the LAN option was set to
enable in the Bios). Flushed back to 1019 and everything is fine again.
Any idea? Thanks in advanced.
Ed
Related Pr oduct
rw
Profile: stranger
More Information
You used the wrong version of aflash, been there...
>Ed
nbk
Profile: stranger
More Information
> Ed
Which program did you use to flash to 1023? Afudos or Aflash?
I used Afudos and did have any problems.
HTH
NBK
nbk
Profile: stranger
More Information
NBK wrote:
>> overclocking failed" message even if it was not overclocked (P4 3.2
>> G). Press F2 will boot to Windows XP but the LAN will not work (the
>> LAN option was set to enable in the Bios). Flushed back to 1019 and
>> everything is fine again. Any idea? Thanks in advanced.
>> Ed
> HTH
> NBK
I meant i had no problems...
More Information
Thanks. I inadvertently used an older version of AFUDOS and that was the
cause. Flushed again with the latest version and every thing is fine now.
Ed
"NBK" <no@spam.net> wrote in message
news:_6aNe.629$ll3.19654@twister.southeast.rr.com...
> NBK wrote:
>>> overclocking failed" message even if it was not overclocked (P4 3.2 G).
>>> Press F2 will boot to Windows XP but the LAN will not work (the LAN
>>> Ed
>> HTH
>> NBK
rw
Profile: stranger
More Information
Glad you figured out that I meant AFUDOS instead of AFLASH.
On Fri, 19 Aug 2005 17:35:36 GMT, "ed wang" <ywang@insightbb.com>
>Ed
>>>> Ed
>>> HTH
>>> NBK
Profile: enthusiast
More Information
hey guys, I have been having issues trying to update the bios on my P4C800E Deluxe. Everytime I try to update using the windows based bios update program it hangs when trying to download the files from the asus website.
Can anyone link me to the best program to use/where to download and which is the best bios update to use.
Currently I have 1017 I believe.
P4C800E, P4 2.8Ghz Prescott, Antec True 550W, 2gb Kingston Hyper X, WD Raptor 74gb, 3x300gb maxtors, ati radeon 9800pro, creative mehh some kinda soundcard. Old system, but 3 years ago it was the shiznit!!!
Any suggestions on link to bios download/update program and the best bios to update to would be appreciated.
Profile: enthusiast
More Information
Quote :
That's never worked for me, because the Asus servers are always busy or the program tries to connect to an non-existing server. So I don't even bother anymore.
The best thing you can do is to go to Asus' website, download the file to your computer and use the same windows program to flash the BIOS. One of the options in the program is to update the BIOS from a file in the PC, so that's the one you should use.
I am also running the 1023 version, and everynow and then I have the overclock failed message. I've noted that - in my case - this happens when I use the BIOS overclock utility with manual settings and then use the windows Asus oc utility with different settings. When I reboot, the settings that have been changed by Windows causes the BIOS to no longer be able to set the OC parameters, thus giving the Oc failure message.
Profile: enthusiast
More Information
ok cool, I will see if i can download the file and go from there. Is 1023 the best new bios to flash to or is there something more stable?
Profile: enthusiast
More Information
Quote :
the 1023 is the latest. It's status is still BETA, but it is quite stable. Go with that.
Profile: enthusiast
More Information
werd, good lookin out, if you dont hear back from me I fried my motherboard trying to update using the lame asus update programs :)
just kidding although when I first bought this board I could update very easily with the windows aapplication that came with it and now I cant update for shizzle.
what happened to asus with this type of bios update, they suddenly bought the big one when it comes to that type of update for some reason or other.
btw, for the new dual core intels is asus still the best board in peoples opinion or is there someone better out there?
Profile: enthusiast
More Information
You're not gonna burn the Mobo! Trust me!
Well, I guess Asus is still THE MOTHEBOARD.
There are many worthy competitors, such as DFI and Abit. They are worth checking out.
The problem with Asus is that their online support sucks big time. They interrupt development of BIOS' when the last release is still beta (such as the 1023). They are also starting to overprice their products, because the market has recognized they have great products.
On the desktop and game machines, I am a loyal Asus customer. However, on the workstation and server, there are many other better manufacturers out there, such as Supermicro.
Add a reply
Google Ads
News
CeBIT 2008: Three new ASUS Motherboards for AMD CPUs
Published on March 05, 2008
ASUS is introducing three new motherboards for the AMD platform at this year's CeBIT - the M3N-HT Deluxe/Mempipe, the M3A32-MVP Deluxe/WiFi-AP and the Crosshair II Formula. All three boards use socket AM2+. Read more
Biostar unveils Nvidia nForce 500 series motherboards for AM2 platform
Published on May 23, 2006
Biostar Microtech on May 23 introduced its new T-series motherboards supporting AMD's AM2 platform and nForce 500 series chipsets, the TForce 590 SLI Deluxe and TForce 570 U Deluxe. Read more
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Biostar unveils Intel P965 motherboard
Published on June 08, 2006
Biostar Microtech International on June 7 announced its new T-series LGA-775 motherboard with the Intel P965 Express chipset. Read more
Latest Reviews & Articles
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
Maxtor's Shared Storage Does NAS At Home
Published on September 25, 2008
What do you do with all the data you collect at home? Network attached storage is the solution. We test Maxtor's Shared Storage II and find that it is also suitable for use in small businesses. Read more
SLI & Centrino 2: Gaming Laptops Battle
Published on September 24, 2008
Take four gaming laptops. Arm two of them with SLI and make the others Centrino 2-compatible. You're looking at a high-end collection of the latest mobile technology battling it out for benchmark supremacy and your hard-earned dollars. Read more
