Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi,
I'm a newbie and have a problem I just can't figure out. My system is:
a7n8x Deluxe
Primary IDE - Master 80GB HD
Slave 40GB HD
Secondary IDE Master TEAC CD RW
Slave Compaq (Panasonic) DVD
512 MB RAM
6600GT Graphics Card
AMD 2400+ XP
Win Xp Pro
My hard drives work fine as does my TEAC CD RW, but I can't get the DVD
to work as the slave on the second IDE. The TEAC is set to cable choice
and the DVD is set to Slave on the jumpers.
The DVD is getting power as I can open and close the draw. The BIOS is
picking up that something is running as the 2nd slave, but puts a
gibberish description when booting up.
Windows sometimes picks up that there is a new cd installed, but won't
let you read any kind of disk from it. It gives a message of "disk is
corrupt..." . Also rather stangely when you select eject for the CDRW
in windows, it opens the draws for both drives!!!
"Bob Badger" <sjdavies47@hotmail.com> wrote in message
news:1124797056.764127.33770@g14g2000cwa.googlegroups.com...
> Hi,
> a7n8x Deluxe
> Slave 40GB HD
> 512 MB RAM
> AMD 2400+ XP
> Win Xp Pro
> Any ideas?
Try setting the TEAC to master, DVD to slave and make sure the TEAC
is the last drive on the cable - this is important. If that doesn't work,
set TEAC to slave, DVD to master and make sure the DVD drive is on
the lst connector of the cable. I've also seen faulty IDE cables cause
this, as well as faulty drives. Avoid setting any drives to cable select
if you can.
HTH
Rob
Tumppi
Reply to group
Most learned on nntp://news.mircosoft.com
Helsinki, Finland (remove _NOSPAM)
(translations from FI/SE not always accurate)
"Bob Badger" <sjdavies47@hotmail.com> kirjoitti viestissä
> Hi,
> a7n8x Deluxe
> Slave 40GB HD
> 512 MB RAM
> AMD 2400+ XP
> Win Xp Pro
That's the problem: you either have both set as master/slave (preferable) or
both as cable select, not mix'n'match :-)
> Any ideas?
> Thanks in advance
> Bob
On 23 Aug 2005 04:37:36 -0700, "Bob Badger" <sjdavies47@hotmail.com>
wrote:
>Hi,
>a7n8x Deluxe
> Slave 40GB HD
>512 MB RAM
>AMD 2400+ XP
>Win Xp Pro
Set the TEAC to Master.
Master drives should be connected to the end of the IDE cable (usually
black color) and Slaves in middle (Gray).
Use 80 pin cables instead of 40 pin cables on CD/DVD doesn't hurt
either.
Thanks guys, I had to set the DVD to master and the TEAC to slave. The
BIOS picked it up straight away, and windows now shows both drives
correctly. The TEAC is still working fine, but I'm still have a few
probs with my DVD. It will read cds no probs, but when I put a dvd in
it looks like it is reading it up just hangs explorer...
news:1124823399.187458.74540@z14g2000cwz.googlegroups.com...
> Any ideas
If you've tried other DVD discs in it and it still hangs, try reading a
CD in it - if that works, you need a new DVD-ROM drive as
the DVD laser might have died (combo drives have 2 different freq.
lasers - 1 for CD, 1 for DVD)
HTH
Rob
