G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I just got an A8V Deluxe motherboard and been having a problem in
starting up the computer.
When I press the on/off button, the system does go through the check
of equipment, and then just sits there, there is no bios boot and no
video
In order for me to get the bios to start it's boot and video, I have
to press the restart button once or twice.........then the bios boots
goes through all the equipment info, and I get one beep with the
message from the bios OverClocking Faliar........
I then press the F1 the bios goes into setup mode, I then press
F10 for save settings...........and then the bios re-starts normaly,
and my computer boot the OS.........no other problems.
I got the latest bios file from Asus, according to Asus Bios 1013 is
the first one that accepts my CPU, so I got both the 1013 and 1014,
use both and have the same problem, with the additional problem in the
1014 that it looses all input settings and reverts to defaul settings
wthich does not happen in the 1013.
My System
AMD Athlon 64 X2 Dual Core 4400
1024 DDR 400 PC3200
MIS GeForce FX 5900 Ultra Video Card AGP
Creative Live 24 Sound Card
Digital Audio Lab Card Deluxe Sound Card
2- Western Digital 250Gig Hard Drives IDE
1- Western Digital 250Gig Hard Drive SATA
Antec Case with 350 ATX 2.0 Smart Power Supply
I've have read in this group that there have been problem with Antec
power supplies with some Asus boards, could this be the cause of my
problems??
video
My System
1024 DDR 400 PC3200
problems??
