Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have an ASUS P4PE with 2.8 Ghz CPU and 1GB ram. OS is Win2k with SP4.
I use a USB mouse (plugged directly into the back of the PC) and also a
Belkin powered USB hub.
When I have my Canon USB scanner plus my i-pod plugged into the hub, I get
an error message saying that there is not enough power to run the USB
devices.
When I have just one device plugged into my hub, I do not get this error
message. I have tried a different model hub (also belkin) with the exact
same result.
So currently my USB hub is useless as I can only plug one device into it.
Has ayone else run into this situation?
Thanks very much
devices.
same result.
Thanks very much
