Front audio panel without affecting rear audio connections
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi there!
I have a A7N8X-E Deluxe mother board. I know it supports a front audio panel
but my computer case doesn't have any. It would be useful when you want to
plug headphones. I would like to install a rack in a front bay but one you
can plug to the mother board's front audio panel connectors and NOT the rear
audio connectors.
Does anyone know a rack that would function in that way please ?
Regards
HappyTheMan
4 answers Last reply
More about front audio panel affecting rear audio connections
  1. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    In article <dggv2l$41t$1@apollon.grec.isp.9tel.net>,
    holymusic@gmail.com says...
    > Hi there!
    > audio connectors.
    > Regards
    > HappyTheMan
    Take a look here: http://www.frontx.com/
    Bill
  2. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    I use the parts from www.frontx.com It works good and is good quality.
    It has a connector that plugs into the motherboard and leaves the rear
    audio connections just as they are. You can plug your headphones into
    the frontx and your speakers will be muted.
    "news.neuf.fr" <holymusic@gmail.com> wrote in message
    news:dggv2l$41t$1@apollon.grec.isp.9tel.net...
    > Hi there!
    > panel but my computer case doesn't have any. It would be useful when you
    > want to plug headphones. I would like to install a rack in a front bay but
    > one you can plug to the mother board's front audio panel connectors and
    > NOT the rear audio connectors.
    > Regards
    > HappyTheMan
  3. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    In article <dggv2l$41t$1@apollon.grec.isp.9tel.net>, "news.neuf.fr"
    <holymusic<at>gmail<dot>com> wrote:
    > Hi there!
    > audio connectors.
    > Regards
    > HappyTheMan
    Page 20 of this specification shows the "standard" for the front
    panel audio connector. This is why it is referred to as
    "Intel compatible":
    http://web.archive.org/web/20040207150757/http://formfactors.org/developer/specs/fpio_design_guideline.pdf
    Here is an example - the Asus J-Panel rack. Note the words
    "Intel front panel audio":
    http://www.office-trade.com/pdf/B99Z429.pdf
    You can build your own front panel drive bay interface,
    with parts from here. This is an expensive method.
    http://www.frontx.com/cpx110.html
    http://www.frontx.com/order2.html
    Here is an example of a Soyo product - Bayone Extreme
    http://www.soyousa.com/downloads/filedesc.php?id=2309
    Good ones are hard to find.
    Paul
  4. Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
    Thanks a lot to you both :)
    regards
    HappyTheMan
Asus Audio Motherboards
