Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have just recently used Windows Update to Update to SERVICE PACK 2.
After the 40 minutes it took to downloand and update I was asked to
restart my computer.
When I resarted my computer I received the following error message. I
cannot boot into windows at all and when I click on "OK" to the error
box I just get a blank screen with my pointer with no desktop icons,
taskbar, or start button.
Here is the error I receive.
" lsass.exe - Entry point not Found " "The procedure entry point c
could not be located in the dynamic link library msvcrt.dll "
This only happened after I updated to Service Pack 2. I have done the
suggest fix on the Microsoft site that says to boot into the XP disk
and use the "r" utility to replace the file "Mscvrt.dll" and that did
not work either.
My computer doesn't work so I am checking this for a different one.
Thanks,
TOM
not work either.
Thanks,
TOM
