Solved
My dvd writer connot read dvd but read cd? what i do to solve this problem
Hello,my dvd writer read cd and some dvd but donot read a lot of dvd .when i insert a dvd in dvd drive and open than so please insert a disc .
5 answers Last reply Best Answer
More about writer connot read read solve problem
  1. Hi, Try updating/reinstalling your drivers, although it sounds like your drive is almost dead and a replacement is the only option.
  2. Sounds like a driver issue, maybe your manufacturer has updated the firmware for the reader.
    However i am agreeing with mibix that you should replace your drive as maybe your current is legacy and does not support the codecs that newer DVD's use.
  3. Best answer
    This is (apparently) quite a common problem with DVD drives. I have seen it happen on at least three separate occasions on three different computers. The drive works perfectly fine for a year or so, then starts to act up. Replacing it is the only solution in my experience.
  4. I believe that there are separate lasers and electronic circuits for the CD and DVD functions. When these drives go it's almost always a question of one of the functions failing (seems to be the CD function usually, but that doesn't mean it can't happen the other way). My DVD writer failed in exactly this way recently; it cost all of £13 to replace it.
  5. Best answer selected by subhajit halder.
Configuration DVD DVD Writers CD-Rom Windows 7
