Archived from groups: microsoft.public.windowsxp.hardware (More info?)
HELP ME PLEASE!!!
I DESPERATELY NEED HELP WITH THESE CONSTANT CRASHES I HAVE
BEEN HAVING. I HAVE DONE SO MUCH TO TRY AND TROUBLESHOOT
IT ALREADY AND HAVENT MADE A BIT OF PROGRESS. IF ANYONE
COULD HELP ME, I WOULD GREATLY APPRECIATE IT.
I WILL OUTLINE EVERYTHING ABOUT THE CRASHES AND EVERYTHING
THAT I HAVE DONE SO FAR...SO THIS WILL BE KINDA LONG, BUT
PLEASE TRY TO READ THE WHOLE THING SO YOU CAN SEE WHAT I
HAVE ALREADY TRIED AND RULED OUT AS BEING THE CULPRIT.
I WILL TRY TO MAKE THE DESCRIPTION AS CLEAR AND DETAILED
AS POSSIBLE BROKEN DOWN INTO SEGMENTS. I WILL TRY TO
INCLUDE EVERY PIECE OF INFO THAT ANYONE COULD NEED IN
TRYING TO HELP ME.
IT WILL BE A LONG POST BUT IT WILL AVOID US HAVING TO GO
BACK & FORTH WITH QUESTIONS AND ANSWERS ABOUT MY SYSTEM
AND WHAT I HAVE TRIED SO FAR...WHICH IS INFO YOU NEED
ANYWAY IN ORDER TO HELP ME....SO I MIGHT AS WELL PUT IT
ALL DOWN RIGHT NOW AT THE START.
I APPRECIATE ANY SUGGESTIONS.
THANKS,
ROB
__________________________________
*PROBLEM*
Any Multimedia program used for ENCODING or RENDERING
audio & video files crashes EVERY time that it is encoding
or rendering. I was able to encode multimedia on this
machine several months ago, but at some point (since i
went months without even trying to encode anything) the
crashes started happening 100% of the time.
*DETAILS*
-I USED TO BE ABLE TO ENCODE VIDEO AND AUDIO ON THIS SAME
HARDWARE until a few months back...I couldnt answer the
all-important troubleshooting question "Well, what changed
right before the failures started?" since I am re-imaging
my operating system every month or so and constantly
downloading & installing new applications...but my
hardware has not changed exept for MAYBE one new Hard
Drive which I cannot recal whether it was installed before
the crashes started or after...but I eliminated this as
the culprit in my troubleshooting steps (Described in
detail far below)
-My system is COMPLETELY free of any virus', adware,
spyware, worms, trojans, or otehr malware...aside from
being completely obsessive about this and running an array
of redundant protection & avoiding exposure in many many
effective ways, my troubleshooting liminated any kind of
malware as being a possible culprit in my troubleshooting
steps (Described in detail far below)
-These crashes go for ANY Multimedia program and ONLY
Multimedia programs (non-audio/video programs seem to work
fine).
-The crash happens at some point DURING the encoding
process, not upon starting the encoding...it will complete
anywhere between 10% to 90% of the process and then crash,
sometimes even further in.
-Occasionally, the same application errors happen during
simply playing of multimedia files, but this is much more
seldom and not something i can replicate at will like when
encoding, which crashes 100% of the time faithfully.
-The crashes happen no matter the format, source, codec,
speed, quality, process priority level nor application
used.
-As for DVD RIPPING, these crashes DO NOT occur when
ripping a DVD to ISO/BIN,CUE/NRG/MDS,MDF/ or FOLDER or
similar....(I GUESS SINCE THOSE DO NOT INVOLVE ENCODING OF
THE VIDEO/AUDIO)....they DO happen if I rip a DVD to
another format (re-encode the video)...even if its Mpeg2
with DVD standards....the key is whether or not i am
encoding
____________________________________
*ERROR DESCRIPTIONS* (divided by "@@@@", my footnotes are
surrounded by "****" )
Program Name.exe - Application Error
The instruction at "0x044a0e06" referenced memory
at "0x03fc5000". The memory could not be "read".
Click on OK to terminate the program
Click on CANCEL to debug the program
****BY THE WAY--The memory address change each time, the
above addresses are one example of a million. Also,
several times the 1st or 2nd address is 0x00000000)****
****Also, some times, the error appears as "...memory
could not be "written"." as opposed to "could not
be "read"."....it really depends on what the application
is doing at the moment....I have found that usually
the "could not be "read"." happen during ENCODING while
the "could not be "written"." happen more during scanning
or preperation of multimedia files....but there are so
many exceptions to this rule that its barely worth
noting.****
****Here is the above error's entry in the Event Log.****
Event Type: Information
Event Source: Application Popup
Event Category: None
Event ID: 26
Date: 8/20/2004
Time: 6:10:52 PM
User: N/A
Computer: 020MAIN
Description:
Application popup: Media Player Classic.exe - Application
Error : The instruction at "0x044a0e06" referenced memory
For more information, see Help and Support Center at
http://go.microsoft.com/fwlink/events.asp.
The exception Breakpoint
A breakpoint has been reached.
(0x80000003) occurred in the application at location
0x07be078e
****This error only happened once or twice in place of the
first error...I havent been able to reproduce this error
ever again, but it must be somehow related since it
occured in the same situation that otherwise brought upon
the other error. I figured it was worth mentioning since
someone might recognize it and not the other error thereby
giving me the answer to both.****
The exception unknown software exception (0xc000001e)
occurred in the application at location 0x053307a0
****This is another one that only happened once or twice
and never again since.****
Event ID: 26
Date: 8/20/2004
Time: 6:08:04 PM
User: N/A
Computer: 020MAIN
Description:
Application popup: Recode.exe - Application Error : The
exception Privileged instruction.
(0xc0000096) occurred in the application at location
0x042e0780.
****Here is another error which only happened once or
twice. As you can see, I didnt get a chance to copy the
exact dialog box, but this was the Event Log entry for it.
______________________________________
-------------END OF ERRORS---------------
*HARDWARE DESCRIPTION*
MOBO Gigabyte GA-7VAXP (ATA 133, AGP 8, more...)
CPU Athlon XP 2000 (1674 mhz, Socket A, MMX, EMMX,
SSE, 3DNOW, Extended 3DNOW)
BIOS Award Modular BIOS v6.00PG, OEM version F14
09/03/2003
CHIPSET VIA Apollo KT400
RAM 256MB DDR PC3200 400MHz (1 Stick)
VGA ATI Radeon 7000 32MB AGP 1,2,4 (currently set to
AGP 4)
SOUND Hercules GameTheaterXP 6.1 External (Onboard sound
disabled)
RAID Onboard Promise 20276 ATA133 or IDE RAID
PRINT Lexmark All-In-One x5150 USB
OPTICAL NEC DVD +/- R/RW ND-2500a - IDE 2, Device 0 (alone
on IDE channel 2)
WEBCAM Concord Eye-Q Duo LCD (Web cam / Digital Camera +
Storage driver)
NIC Onboard Realtek 10-100 Fast Ethernet PCI
NET Cable modem, over 3.5 megabit per second
DRIVES:
*20gb Maxtor - 1 20gb NTFS Partition (C:\, Windows Drive) -
IDE 1, Device 0
*250gb Western Digital - 1 250gb Partition (D:\, Storage +
my only Pagefile) - IDE 1, Device 1
*80gb Maxtor - 1 80gb NTFS Partition (E:\, Storage) - IDE
3, Device 0 (Promise Controller)
*30gb Seagate - 1 30gb NTFS Partition (F:\, Storage) -
IDE 3, Device 1 (Promise Controller)
*10gb Western Digital - 1 10gb NTFS Partition (G:\,
Storage) - IDE4, Device 0 (Promise Controller)
*8gb Western Digital - 1 10gb NTFS Partition (H:\,
Storage) - IDE4, Device 1 (Promise Controller)
*SYSTEM DESCRIPTION* (Changed many times during
troubleshooting)
Windows XP Pro (no Service pack, then SP1, Now
SP2...crashed with all)
500 mb Pagefile on D:\ (crashed with pagefile in various
sizes and locations)
*SOFTWARE DESCRIPTION*
Norton Internet Security 2004, updated daily (crashed with
or without)
Norton Antivirus 2004, updated daily (crashed with or
without)
Many applications of various types. (crashed with all or
without any)
Many applications for multimedia editing, encoding, and
playing (crashed with all or without any)
ACE Mega Codec pack full install (crashed with or without)
K-Lite Codec Pack Full Install (crashed with or without)
_______________________________________
*TROUBLESHOOTING STEPS TAKEN SO FAR*
(I duplicated the crashes under all of the following
conditions and after performing all of the following steps)
-Changed settings for pagefile size and locations in every
possible way
-Disabled all non-critical background services one at a
time
-Disabled all non-critical hardware one at a time (both in
Windows and in BIOS) like IDE controller 2, Promise IDE
RAID controller, on board hardware, etc etc
-Disabled all non-critical drivers one at a time
-Uninstalled all non-critical hardware & drivers one at a
time (both in Windows and by physically removing)
-Uninstalled (physically) all hard drives one at a time
-Uninstalled all codecs and software one at a time
-Uninstalled Anti-Virus & Firewall one at a time, tried
different brands (Avast, Black Ice, Panda, McAfee, etc)
-RE-IMAGED PC WITH FRESH WINDOWS XP PRO INSTALLATION, NO
SOFTWARE (other than test program), NO UPDATES (at first),
NO NON-CRITICAL DRIVERS
-RE-IMAGED PC WITH FRESH WINDOWS 2000 INSTALLATION, NO
-Incrementally installed different services, programs,
security apps, drivers, codecs, and windows updates to
both FRESH Windows (XP & 2000) Installations...testing
after each change
-Tested each system configuration with every multimedia
encoding application at my disposal (over 30 programs from
different vendors)
-Reverted back to old versions of all hardware drivers one
at a time
-Updated to newest versions of all hardware drivers one at
a time
-Re-seated my only 256MB RAM stick into each of the 3
slots one at a time
-Ran 2 different RAM testers OUTSIDE of windows (Microsoft
and MemTest86) for over 24 hours each...passed all tests
(both set to thorough testing)
-Ran MEMTEST (Windows memory testing app) from within
windows for 8 hours....passed all thorough tests
-Ran Performance Test (from Norton System Works) using
various tests for Memory, Bus, hard drives, page files,
AGP, and CPU (multimedia & math)...passed all
-Ran burn-in tests using SiSoft Sandra 2004 on Memory,
drives, CPU Multimedia, CPU math, page file, AGP, SCSI,
and File system....passed all intense benchmarking tests
with expected results for each model hardware
-verified all IRQ, IO, and DMA for conflicts
-Tuned write caching off and on
-installed windows (XP & Pro) on different hard drives,
using only that hard drive on the system
-Defragged all hard drives using O&O Defrag will they were
down to less than 1%-3% fragmented
-Reverted BIOS to safe settings, high-performance
settings, default settings, custom sensible settings and
every other possible config...making changes one at a time
-Flashed BIOS to newer version (F14 up from F4)...despite
encoding had worked in the passed on the old version
etc etc etc.....whew!
*CONCLUSION*
I seriously have done more than even what I listed above,
but that is all that comes to my mind right now as I type
this....and this post is already long enough for you guys
to not wanna bother reading
From looking at all the troubleshooting that I have done,
you can imagine how frustated I am already...I have run
out of things to try...
the most confusing things are the fact that I USED TO BE
ABLE TO ENCODE VIDEO AND AUDIO on this machine....so when
you consider all of my different troubleshooting, it leads
you to blame some piece of hardware having gone bad at
some point after my last successfull video/audio encoding
several months ago (since the hardware is the only thing
that I couldnt swap for testing in my troubleshooting
steps)....but then all of the hardware passes all of the
stress tests and benchmarking that i throw at it...
ANY SUGGESTIONS ARE GREATLY APPRECIATED....
THANKS IN ADVANCE!!!!!
I have seen problems like this developing after a substantial period
(months) of normal use and apparently resulting from marginal memory
which produced errors when the system got hot when maximally
exercised. The memory in this case passed Memtest-like diagnostics
(probably because the video card was not also being stressed/producing
heat while the memory was being tested in this way), though I did not
test it as exhaustively as you appear to have tested yours.
The only other hardware causes of tis sort of behaviour which spring
to mind are processor overheating (has the goo between your processor
and its heat sink dried up?) and a flaky power supply - but I think
that the latter is unlikely.
I would use an appropriate utility to check your CPU temperature when
you are doing the things that cause your system to crash. If it is too
high, remove, clean, and replace (with new thermal "goo" ) your CPU
heatsink, and see if that helps. If it is not the CPU, I would replace
the memory with 512 MB of top of the line (e.g. Crucial) SDRAM.
On Mon, 27 Sep 2004 10:29:12 -0700, "ROBERTO - IN DESPERATE NEED OF
HELP" <THEREBELMINDat-HOTMAIL-DOT-COM@discussions.microsoft.com>
wrote:
>HELP ME PLEASE!!!
>TRYING TO HELP ME.
>THANKS,
>ROB
>*PROBLEM*
>*DETAILS*
>detail far below)
>fine).
>used.
>encoding
>noting.****
>Event ID: 26
>Date: 8/20/2004
>Time: 6:10:52 PM
>User: N/A
>Computer: 020MAIN
>Description:
>0x07be078e
>Event ID: 26
>Date: 8/20/2004
>Time: 6:08:04 PM
>User: N/A
>Computer: 020MAIN
>Description:
>0x042e0780.
>09/03/2003
>AGP 4)
>disabled)
>on IDE channel 2)
>Storage driver)
>DRIVES:
> IDE 1, Device 0
>troubleshooting)
>or without)
>without)
>without any)
>possible way
>time
>after each change
>different vendors)
>at a time
>a time
>slots one at a time
>*CONCLUSION*
Please respond to the Newsgroup, so that others may benefit from the exchange.
Peter R. Fletcher
First, you aren't going to get much help especially since your CAPS
LOCKS button is stuck on. Reinstall all drivers and all software. If
that doesn't work, reinstall Windows.
Nathan McNulty
ROBERTO - IN DESPERATE NEED OF HELP wrote:
> HELP ME PLEASE!!!
> TRYING TO HELP ME.
> THANKS,
> ROB
> *PROBLEM*
> *DETAILS*
> detail far below)
> fine).
> used.
> encoding
> noting.****
> Event ID: 26
> Date: 8/20/2004
> Time: 6:10:52 PM
> User: N/A
> Computer: 020MAIN
> Description:
> 0x07be078e
> Event ID: 26
> Date: 8/20/2004
> Time: 6:08:04 PM
> User: N/A
> Computer: 020MAIN
> Description:
> 0x042e0780.
> 09/03/2003
> AGP 4)
> disabled)
> on IDE channel 2)
> Storage driver)
> DRIVES:
> IDE 1, Device 0
> troubleshooting)
> or without)
> without)
> without any)
> possible way
> time
> after each change
> different vendors)
> at a time
> a time
> slots one at a time
> *CONCLUSION*
Nathan...
I appreciate the response...but you shouldve actually read
my issue and not just glanced at the first paragraph...
Firstly, the CAPS LOCK key wasnt stuck...I only used it to
differentiate the "personal introduction" and my plea for
help from the actual description of my issue....90% of my
post was not in CAPS..
Second...the whole "CAPS LOCK IS RUDE" thing is reserved
for children who make their lives online, social and
otherwise...since only children or those with child-like
thoughts would ever feel the need to have their
TEXT "shout" at someone they never met (nor will ever
meet) from across the country.
Since I cannot imagine a situation where a mature person
would ever feel the need to "text scream" at someone, I
use capital letters like the rest of the sane world does
(aside from standard capitalization)...to express
importance or otherwise draw attention to the words
written in capitals.
Now then, back to the matter at hand...if you would have
taken the time to read my post as opposed to using that
time to critique my capitalization, you would realize that
I have already reinstalled every driver several times with
various versions each, disabled, re-enabled, and
physically removed every piece of non-critical hardware in
my PC...and as for reinstalling Windows...I have done that
several times...using both Windows XP Pro as well as
Windows 2000 Pro...both installed and tested and crashed
before ANY drivers, service packs, programs, or anything
else...with no luck....then I incrementally installed
every hardware component, driver, program, patch, upgrade,
service pack, codec and whatever else....testing after
each change (as one would do in good troubleshooting
practice)...no luck
I really do appreciate the help, I wasnt being
sarcastic...but in order to help me, you gotta know what
the problem is and what ive done so far...and thats why I
spent so much time typing that long-ass post...so as to
avoid the inevitable (and needed) Q&A about what was tried
and what the circumstances were...
....its already ready already
<anonymous@discussions.microsoft.com> wrote in message
news:23be01c4a4c7$0a4afbf0$a501280a@phx.gbl...
Firstly the ettiquette of reserving caps for shouting was introduced
by bearded middle aged geeks not children.
Secondly "....at someone they never met (nor will ever meet) from
across the country" country? you're American right?
Since you seem to have no regard for the well established customs of
USENET, why not go the whole hog and use HTML so you can differentiate
between information and a plea for help?
As for your problem it seems you have tried every software
troubleshooting route ever invented plus a few more. I would like to
suggest that either your RAM is in fact failing despite the passed
tests ( I have had sticks pass memtest shortly before falling over) or
more likely, you mentioned no hardware changes except a new hard disk,
your system has 4 hard drives and an optical drive all on a system
that looks to be a couple of years old (originally) at least is your
power supply original? It could be possible that unless you do in fact
have at least a 400W PSU that too much power is being drawn by the
drives causing the CPU and Memory to be underpowered when they are
doing intensive Multimedia Tasks. Even though you have run the system
with less drives in and still got the same unfortunate result it may
be possible that the PSU or perhaps even the motherboard has suffered
some minor little error as a result that is now causing your problems.
I may be way off but PSU's are cheap enough to give it a try.
I read a bit of "I like toys..." response, but they yelling part isn't
really my problem. It is harder (for me at least) to read when
everything is in CAPS LOCKS. I could care less if it was rude or
shouting as much as it is a "pay more attention to me because I'm
special" way of typing and difficult to read. This is the real reason
most people will pass over a message like this.
As for your problem, how are the temperatures inside your computer. If
even a clean install of Windows is "crashing" (which you need to
define), then there is something wrong with the hardware physically.
You may want to get another stick of memory to compliment the existing
stick as it will not only help improve system performance, but take a
little load off the CPU/HD.
I did actually read into your post further than just the caps, but much
of the content was not helpful unless we actually had the source code to
work with. The one thing that should have been in Caps or pointed out
better was this:
"These crashes go for ANY Multimedia program and ONLY
fine)."
There are three possibilities here. First, the software. Second, the
drivers. Finally, the physical hardware. If it is just encoding, it is
most likely the software since your computer was able to perform burn in
tests without heat issues.
Try this:
Boot off the XP CD, delete the partition, create a new partition, format
NTFS {Quick), Install Windows (with SP1a or SP2 slipstreamed if you
like), then install the latest version of VirtualDub. Try using that to
convert a video file to something else.
Nathan McNulty
To "I Like Toys & Cake" & Nathan...
all good suggestions...and I know I got a bit defensive
about the caps lock issue...its just that Im at the end of
my rope with this 4 month long troubleshooting marathon.
Youre right, despite all my troubleshooting I never
switched the hardware components other than Hard
drives...the reason is that I didnt really have any extra
hardware at my disposal (not anything less than 4-6 years
old, anyway)...so I resorted to and relied upon redundant
and thorough hardware testing using diagnostic and
benchmarking software...which as one of you pointed out,
is not fool-proof nor guaranteed to show every single
possible hardware flaw.
and as Nathan pointed out, my troubleshooting really
eliminated everything except hardware, which despite
success in testing,is looking like the main suspect.
BUT...
***I Have made some progress since my last post! Not 100%
solved, but about 80%...which has only served to further
confuse me as to what the problem is about.
Here's what happened....
First, the only thing that I have done so far (which I did
only yesterday)which had apparently solved the issue was
upgrading my BIOS
It might have seemed obvious, but since I was encoding
videos just fine on my old old BIOS version (version F4)
and then upgraded several months ago to F14 and never
encoded successfully after that (I hadnt needed to encode
video for months...in the middle of which I updated the F4
BIOS to F14, so I didnt BLAME the F14 version either)
Yesterday, I finally decide to pull a "Hail Mary" and
update to newest version, F15...
SUDDENLY, everything seemed to work....all the
applications that crashed with the same application errors
100% of the time each suddenly worked 10 times in a row
during testing of video encoding...long videos, short
videos, various formats, various source material and
material properties...etc etc...
I figured that it probably wasnt that F14 was bugged (F14
was the BIOS version which the problem started under),
since F15 only changed one small bit from F14...and it
wasnt the settings reset since I had tried every possible
CMOS setting combination in my troubleshooting steps...I
figured that perhaps MY particular BIOS had become
partially corrupted...that, coupled with some other
mystery ingredient (probably video driver related) caused
my application crashes.
~~~****Then, as I continued testing, I got the same
application errors on occasion (meaning once after 20
successfull encodings in a given application)...
I cannot tell you how broken-hearted I was to see that
error dialog box pop up after I had already did everything
to celebrate my victory except stand in the mirror with my
shirt off and flex.
Since I dont have the monetary mean$ to buy more RAM (I
wish I did cuz I need more), a bigger PSU (I wish I did
cuz I need one), or a better video card (I wish I did cuz
I need one), I am about to try another vga driver update
to the latest version (which didnt work before, but under
the new BIOS, who knows)...
Also, I am going to run through my CMOS yet again to try
tweaking one pertinent thing at a time if the vga driver
update does nothing.
after that, who knows....Im pouncing on my last bit of
patience as far as this issue goes...and now that its only
failing maybe 10% of the time, my testing just got much
much harder than when it was crashing 100%
as for the heat issue....thats something I hadnt thought
of until yesterday when someone in the other newsgroup
here suggested it...so I monitored the box and cpu heat as
the application errors happened (before my partially
fixing it)...all were normal...especially since I never
overclock anything (I cant afford to get cute with
hardware that I cant afford to replace if I burn it out)
thanks to you all...
If you think of anything else in light of what I said
about the 90% fix, please let me know...I really really
appreciate all of your help and advice
here is a more detailed description of what I have done
and "accomplished" since yesterday...forgive any redundant
info when compared to my 3rd reply (just above this reply)
I tried the newest and oldest vga drivers like I said I
was going to do...
the newest did nothing to help, the oldest gave me
bluescreens...
BUT, the bluescreens helped in a way....because on the
blue screens that specifically called out my ati vga
drivers as being the cause, they also had the memory
addresses...
and they were the SAME addresses that would come up 70% of
the time in the application errors within windows that I
describe in my original post and that are the very issue
that I am trying to solve here!
*****ALSO....after that, I reverted back to the december
2003 ati drivers that Windows XP + SP1 automatically
install upon user logon when no vga drivers are installed
for my radeon 7000...AND THEN I UPDATED MY BIOS from
version F14 to F15 (latest version)
THIS FIXED MY PROBLEM (I thought) 100%....
I tested and tested and tested and tested....all the
applications that would crash 100% of the time on trying
to encode video would now run flawlessly!!!!
I ran programs through various encodings at least 5-15
times each!!! all worked fine after BIOS update (my old
F14 version mustve gotten corrupted at some point, im
guessing)
BUT THEN.......it happened....Application errors....just
like before....only now they happened ONCE for every 10 or
20 encodings!!!....
this only confused me more! how did I solve 90% of the
problem???
So now, I will again try installing the new vga driver
that didnt work before...since now, it might work with the
new BIOS...
after that, maybe tweak/test/tweak/test some settings
related to possible culprits in the CMOS....
I am almost convinced that the problem lies between the
BIOS and the VGA driver/card/vga card memory....I could be
wrong, but everything that I have researched, tested,
partially solved, and read from blue-screens leads me in
that direction...
anyone have any suggestions in light of what I have done
up until now??
Another thing that sounds stupid but you may want to try is switching
out the IDE cable. Sometimes they do have problems which may be a
culprit here. Just a last thought
Nathan McNulty
> was going to do...
> bluescreens...
> addresses...
> guessing)
> 20 encodings!!!....
> problem???
> new BIOS...
> that direction...
> up until now??
There are 1280 identified and unidentified users. To see the list of identified users, Click here.
