Maxtor 160 Gb HD (6Y160P0) PIO Problem
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
New 160Gb Drive (6Y160P0), still remains in PIO mode -
Windows XP SP2, fresh install.
Tried all help from KB817472 - No Joy, changed cable
positions, problem follows drive. BIOS reports 160Gb
drive - UDMA5. Maxtor Utils report 160Gb Drive.
Cannot move the drive from PIO to UDMA.
Similar Maxtor Drive works, shows UDMA5. 5T060H6
Any suggestions please??
Thanks.
Thanks.
More about : maxtor 160 6y160p0 pio problem
Is there any other device on the same IDE cable?
Cari (MS-MVP Windows Client - Printing, Imaging & Hardware)
www.coribright.com
"brandie" <anonymous@discussions.microsoft.com> wrote in message
news:3ecf01c4a4e4$ea071d10$a401280a@phx.gbl...
> Thanks.
www.coribright.com
> Thanks.
Yes, another Maxtor 60Gb (5T060H6)- Shows up as UDMA 5
Tried without extra HD, 160Gb HD still locked in PIO.
Tried with another Brand New 160Gb Drive - Exactly same
problem.
Re-loaded Win XP SP1 from CD. Still shows as PIO,
Upgraded with SP2 CD - Still PIO.
Tried all positions on cable and with the 60Gb Drive,
Changes to UDMA5. I suspect that Win XP can't recognise
Maxtor chipset - Your Comments?
I am really stumped on this one, and so are a lot of
others with new 160Gb and 200Gb HD's
Any more Ideas please.
>-----Original Message-----
Hardware)
>www.coribright.com
message
>> Thanks.
problem.
Hardware)
>www.coribright.com
message
>> Thanks.
Try CS (Cable Select) and see if that makes a difference.
www.coribright.com
news:3f3501c4a5bb$4409b210$a301280a@phx.gbl...
> problem.
> Hardware)
>>www.coribright.com
> message
>>> Thanks.
www.coribright.com
> problem.
> Hardware)
>>www.coribright.com
> message
>>> Thanks.
Related ressources
- Maxtor 6Y160P0 wont boot after Ghost attempt - Forum
- Problems with PIO , Maxtor 160Gb and A7A266 with Ali chipset - Forum
- Maxtor 160Gb very loud! - Forum
- Maxtor Sata 160Gb - Forum
- hard disk for video editing under Windows XP : MAXTOR Diam.. - Forum
Two (desperate) thoughts:
1. During setup did to format to one 160 GB partition or more than one (all
under 137 GB)?
2. Could this be a motherboard limitation (ie a 32bit IDE channel and not a
48 bit as is supposedly required to support over 137 GB)?
In my situation I added a Western Digital 160GB HDD via a Promise
Ultra100TX2 IDE card. With the Maxtor you would probably want the
Ultra133TX2 to match the drive speed.
r.
"Cari (MS MVP)" <Newsgroups1@coribright.com> wrote in message
news:eTritgepEHA.592@TK2MSFTNGP11.phx.gbl...
> www.coribright.com
>> problem.
>> Hardware)
>>>www.coribright.com
>> message
>>>> Thanks.
under 137 GB)?
r.
> www.coribright.com
>> problem.
>> Hardware)
>>>www.coribright.com
>> message
>>>> Thanks.
No difference at all I'm afraid.
Hardware)
>www.coribright.com
message
>> problem.
recognise
>> Hardware)
>>>www.coribright.com
in
>> message
mode -
>>>> Thanks.
Hardware)
>www.coribright.com
message
>> problem.
recognise
>> Hardware)
>>>www.coribright.com
in
>> message
mode -
>>>> Thanks.
1. Two partions 80Gb each
2. How could I check for certain whether it is 32 or
48bit?
Many thanks for your comments
more than one (all
>under 137 GB)?
a Promise
probably want the
>r.
message
difference.
Hardware)
>> www.coribright.com
in message
same
>>> problem.
recognise
>>> Hardware)
>>>>www.coribright.com
in
>>> message
mode -
>>>>> Thanks.
48bit?
more than one (all
>under 137 GB)?
a Promise
probably want the
>r.
message
difference.
Hardware)
>> www.coribright.com
in message
same
>>> problem.
recognise
>>> Hardware)
>>>>www.coribright.com
in
>>> message
mode -
>>>>> Thanks.
Motherboard manual if you have it otherwise visit manufacturers website for
e-manual download (pdf file).
One other thought. Have you gone to the motherboard manuf website to see if
BIOS and Chipset drivers are available. This may help your situation.
Backup data before doing any updates!!!
My motherboard is MSI:
http://www.msicomputer.com/support/TechSupport.asp
If yours is MSI then look for a utility update program called MSI Live
Monitor.
r.
"Brandie" <anonymous@discussions.microsoft.com> wrote in message
news:189d01c4a643$f8c73140$a601280a@phx.gbl...
> 48bit?
> more than one (all
>>under 137 GB)?
> a Promise
> probably want the
>>r.
> message
> difference.
> Hardware)
>>> www.coribright.com
> in message
> same
>>>> problem.
> recognise
>>>> Hardware)
>>>>>www.coribright.com
> in
>>>> message
> mode -
>>>>>> Thanks.
Monitor.
r.
> 48bit?
> more than one (all
>>under 137 GB)?
> a Promise
> probably want the
>>r.
> message
> difference.
> Hardware)
>>> www.coribright.com
> in message
> same
>>>> problem.
> recognise
>>>> Hardware)
>>>>>www.coribright.com
> in
>>>> message
> mode -
>>>>>> Thanks.
Went to mfr site. Confirms that the BIOS correctly
supports 48bit LBA.
My motherboard is Asustek A7A266 with AMD Athlon 1400 CPU
No other drivers appear to be available. I have Bios 12.
your situation.
called MSI Live
>Monitor.
>r.
message
>> 48bit?
or
>> more than one (all
>>>under 137 GB)?
GB)?
>> a Promise
>> probably want the
>>>r.
>> message
>> difference.
>> Hardware)
>>>> www.coribright.com
>> in message
UDMA 5
PIO.
>> same
>>>>> problem.
Drive,
>> recognise
>>>>> Hardware)
>>>>>>www.coribright.com
wrote
>> in
>>>>> message
>> mode -
cable
160Gb
>>>>>>> Thanks.
supports 48bit LBA.
your situation.
called MSI Live
>Monitor.
>r.
message
>> 48bit?
or
>> more than one (all
>>>under 137 GB)?
GB)?
>> a Promise
>> probably want the
>>>r.
>> message
>> difference.
>> Hardware)
>>>> www.coribright.com
>> in message
UDMA 5
PIO.
>> same
>>>>> problem.
Drive,
>> recognise
>>>>> Hardware)
>>>>>>www.coribright.com
wrote
>> in
>>>>> message
>> mode -
cable
160Gb
>>>>>>> Thanks.
Last thought for now:
Is the ribbon cable connecting the 160 GB have 80 or 40 wires (one wire is
per each little rib in the cable). It should be 80 wire cable (40
conductors, 40 ground wires).
r.
news:25b501c4a71c$32360360$a601280a@phx.gbl...
> supports 48bit LBA.
> your situation.
> called MSI Live
>>Monitor.
>>r.
> message
>>> 48bit?
> or
>>> more than one (all
>>>>under 137 GB)?
> GB)?
>>> a Promise
>>> probably want the
>>>>r.
>>> message
>>> difference.
>>> Hardware)
>>>>> www.coribright.com
>>> in message
> UDMA 5
> PIO.
>>> same
>>>>>> problem.
> Drive,
>>> recognise
>>>>>> Hardware)
>>>>>>>www.coribright.com
> wrote
>>> in
>>>>>> message
>>> mode -
> cable
> 160Gb
>>>>>>>> Thanks.
r.
> supports 48bit LBA.
> your situation.
> called MSI Live
>>Monitor.
>>r.
> message
>>> 48bit?
> or
>>> more than one (all
>>>>under 137 GB)?
> GB)?
>>> a Promise
>>> probably want the
>>>>r.
>>> message
>>> difference.
>>> Hardware)
>>>>> www.coribright.com
>>> in message
> UDMA 5
> PIO.
>>> same
>>>>>> problem.
> Drive,
>>> recognise
>>>>>> Hardware)
>>>>>>>www.coribright.com
> wrote
>>> in
>>>>>> message
>>> mode -
> cable
> 160Gb
>>>>>>>> Thanks.
It is an 80 wire cable. Cable OK, tried with other drives.
Thanks for all your suggestions Namniar, much appreciated.
wires (one wire is
cable (40
>r.
message
>> supports 48bit LBA.
CPU
12.
>> your situation.
>> called MSI Live
>>>Monitor.
wires (one wire is
cable (40
>r.
message
>> supports 48bit LBA.
CPU
12.
>> your situation.
>> called MSI Live
>>>Monitor.
Think this is a quick fix
see if it helps
email me if it works pder90@shaw.ca
go to your ide ata/aatapi controllers
there should be 2 controllers
click on the corresponding controller and update it.
window will ask to connect to window update... no
install from a list advance
don't search. i will choose the driver to install
select intel ultra ata storage controllers -24db
restart and you are at ultra dma 5.. but faster
all done... don't forget to mail me if it helped
On Mon, 27 Sep 2004 15:54:15 -0700, "brandie"
>Thanks.
see if it helps
>Thanks.
Hi All ,
Is this problem fixed?
I think i have tried all the things mentioned on this thread already ,
but still no lucks ,if you have already fixed this please share it with
me.
I'm so in the trouble with this harddisk.
Best Regards,
Penny2524
penny2524
penny2524's Profile: http://www.msusenet.com/member.php?userid=259
View this thread: http://www.msusenet.com/t-1223912
Hi All ,
me.
Best Regards,
Penny2524
penny2524
Related ressources:
- ForumDMA problem with MAXTOR HD
- ForumMaxtor 160GB in 1394 case A-Tec CD-503FW=128 GB !?!
- ForumPlease help! SATA HD boots up in UDMA5, drops to PIO
- ForumGA-7VAX On boot my HD is not recognised as ATA 100 but PIO 4
- ForumPIO Mode in Windows 2000
- ForumProblem Installing Win XP Pro SP3 on a 160 GB HD
- ForumHardware reports PIO instead of DMA on disks (asus a7n8x m..
- ForumHDTune Results PIO Mode/Lockups
- ForumAdding a Maxtor 160 gig in Windows 98SE?
- ForumGA-81PE1000G - IDE HDD only runs in PIO mode
- ForumPSU comparison - opinions wanted
- ForumPCMCIA slots need more power??? HELP!
- ForumAti 9800 pro problem
- ForumNetwork Problem
- More resources
Read discussions in other Windows XP categories
