Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
Neither of you are alone, I had the same thing and unfortunately my
electronic engineer friend found in my case it was a faulty micro
switch (most likely caused by pounding on it while playing online
games) anyway the fix - replacement mouse, the new one works fine.
To diagnose if you have the same fault set up the mouse for left
handed use in it's setting i.e. swap over the left and right buttons.
If clicking with the right button works then the microswitch on the
left one is broken as mine was.
"kferro" <kferro@discussions.microsoft.com> wrote in message
news:06EC24EB-49A0-493C-B3D9-73E2EC3E29CD@microsoft.com...
> Well, unfortuneately I'm not writing with a solution, but to tell
> you you're
> not alone.
> Like you, I often have to click two times when only one click is
> needed, and
> like you, it's fairly erratic. I've found that if I click and hold
> for a
> second or two, the click will "take", but that should not be normal
> for any
> mouse, especially a $40 one.
> I've scoured the microsoft website looking for info regarding a
> return (I
> know longer have the receipt and the 30-day store return policy has
> expired),
> but to no avail . . . I can't even find a phone number!
> HELP!!!
> "Tony Kongsmark" wrote:
>> Hi.
>> My Intellimouse Explorer 4.0 USB is making trouble with the left
>> mouse
>> button.
>> It's erratic and more often than not requires more then 1 press to
>> "take"
>> the click and give respons.
>> I have tried to change around on the buttons, but have not succeded
>> in any
>> change yet.
>> Anybody?
>> Win XP Pro
>> SP1
>> AMD 2500+ Barton
>> 512MB PC2100
>> Asus A7N8X
>> Best regards
>> Tony K.
