Tom's Hardware > Forum > Motherboards & Memory > Elitegroup > Correct battery for K7S5A?
Forum Motherboards & Memory : Elitegroup - Correct battery for K7S5A?
Archived from groups: alt.comp.periphs.mainboard.elitegroup (More info?)
I suspect that my (CMOS) battery in my K7S5A is going; I've had Windows XP
freeze solid roughly once a day for the last several days. The CPU Fan
Speed, System Temp, and CPU Temp all seem reasonable so I'm guessing it's
the battery.
I'd like to go out and buy the replacement without first opening the case
but I can't find anything in the manual for the motherboard that says what
battery to use. Can someone tell me what battery I need or where to look for
the answer. I've tried googling and asking a friend with the same
motherboard but I have three different answers so far so I don't know what
to believe any more.
Rhino
rhino1 AT sympatico DOT ca
"There are two ways of constructing a software design. One way is to make it
so simple that there are obviously no deficiencies. And the other way is to
make it so complicated that there are no obvious deficiencies." - C.A.R.
Hoare
Sponsored Links
On Thu, 16 Sep 2004 15:16:40 -0400 Humanity I love.It's just people
>the battery.
Any decent 2032.Duracell are good.You can get them
from,"WallMart/Staples".
HTH :)
Free Windows/PC help,
http://www.geocities.com/sheppola/trouble.html
remove obvious to reply
email shep@obviouspartyheld.de
Free songs to download and,"BURN" :O)
http://www.soundclick.com/bands/8/nomessiahsmusic.htm
Reply to Anonymous
- 0 +
"Shep©" <nospam@nospam.net> wrote in message
news:cftjk0hmgb8iflnd0dvvu7eq1n1i46agte@4ax.com...
XP
> >the battery.
what
for
what
> HTH :)
Thanks!!
Rhino
Reply to Rhino
On Thu, 16 Sep 2004 17:50:25 -0400 Humanity I love.It's just people
>XP
>> >the battery.
>what
>for
>what
>> HTH :)
>Thanks!!
>Rhino
If it don't fix it you may have to use an O/B BIOS and pump up to
138/138.This usually fixes the lost CMOS/BIOS reset.
Check here,
http://p199.ezboard.com/bk7s5amotherboardforum
Daft as it is the old K7S5A runs better at these speeds :P
Can help with BIOS update as well.See sig for email :)
Reply to Anonymous
>XP
>> >the battery.
>what
>for
>what
>> HTH :)
>Thanks!!
>Rhino
If it don't fix it you may have to use an O/C(Overclock) BIOS and pump
up to
Check here,
Reply to Anonymous
"Rhino" <rhino1@NOSPAM.sympatico.ca> wrote in message
news:%Dl2d.21173$0h7.1496109@news20.bellglobal.com...
Windows XP
Fan
it's
| the battery.
case
says what
look for
know what
I really don't think a bad battery will cause freezeups. It might
cause loss of the real time clock accuracy or cause loss of CMOS
settings, but if the system does not complain about CMOS checksum
errors on power up, then the battery is probably ok. BTW, Vbat is the
battery voltage, what does CMOS setup report?
Best regards,
Kyle
Reply to Anonymous
- 0 +
"Kylesb" <me@privacy.net> wrote in message
news:2qves7F14gsrmU1@uni-berlin.de...
> Windows XP
> Fan
> it's
> | the battery.
> case
> says what
> look for
> know what
I agree with what Kyle said about a bad battery and what you'd likely
experience.
K7S5A ships with a very low quality battery, KTS. The battery the board
takes is a CR2032 (if you open your case and take it out you will see for
sure). They cost $3 at Radio Shack and actually say Toshiba, Panasonic,
Sony, etc., on them. It doesn't hurt to change it out just for piece of
mind, knowing you won't have a related problem for years.
Heat is what might normally cause your freezing problem. Have you installed
anything or done updates recently?
Reply to Smoker
There are 1247 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
