Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Using W2K HOST with Dial Up Wireless networked ( Linksys wireless router ) to
a LAPTOP O/S win XP- Home. Network is no isuue, but the LAPTOP will not ICS
with the HOST. Tried running the Wireless Network Wizzard. Does not see the
Sharred Connection. ( NOTE -If I run the Wired Network Wizzard, it does see
the the ICS connection - BUT I AN NOT USEING HARD WIRED - so this does me no
good)
Hi
May be you should explain better the way every thing is connected. If you
have a Wireless Router (working as a Router) then you do not need ICS.
On the other hand it is a DialUP (internal modem???).
So how the Router is connected (WAN Port? Regular port? what IP? DHCP is On
or Off? Etc.)
Jack (MVP-Networking).
"Rodney L. Voumard" <RodneyLVoumard@discussions.microsoft.com> wrote in
message news:91488ABD-FB2F-4CDB-9916-4805950E0B74@microsoft.com...
to
ICS
the
see
no
> good)
> Suggestions - Help ??
> Rodney
Thanks for the POST----
DIAL UP Internal Modem ( my only choice in my area ) in Desktop PC
Desktop PC connected to ROUTER WAN port w/CAT5E through NIC card
Laptop PC Connected via Wireless Networking Connection.
Both PC NIC TCP/IP set to obtain I/P AUTO
Router set to AUTO DHCP
Both PC's on the network OK - can Share both printer and files. Desktop PC
Can Connect to internet, Laptop has been unable to use ICS.
WIN2K O/S - Desktop
Win XP-Home O/S Laptop
The concept seems simple .........but after 3 day's
THANKS AGAIN
"Jack" wrote:
> Hi
> or Off? Etc.)
> to
> ICS
> the
> see
> no
> > good)
> > Rodney
message newsABC0D11-7C3F-45FA-BC97-0E36995C654F@microsoft.com...
> WIN2K O/S - Desktop
> THANKS AGAIN
> "Jack" wrote:
> > Hi
you
On
> > or Off? Etc.)
router )
> > to
not
> > ICS
see
> > the
does
> > see
me
> > no
> > > good)
> > > Rodney
Thanks for the help !!
I will give this a try. As long as I do not lose my file/printer sharing. I
really don't care if I use a ROUTER or ACESS POINT ( did not now that a
ROUTER would double as a ACESS POINT...)
Rodney.
"Jack" wrote:
> Hi
> ICS can not work with such setting.
> You should connect the Wireless Cable/DSL Router as an Access Point.
> I.E. connect it to the host desktop via a regular port and switch off the
> DHCP.
> More instructions here: http://www.ezlan.net/router_AP.html >
> And here:
> http://www.microsoft.com/windowsxp [...] 02april08. > mspx?pf=trueHi
> > WIN2K O/S - Desktop
> > THANKS AGAIN
> > "Jack" wrote:
> > > Hi
> you
> On
> > > or Off? Etc.)
> router )
> > > to
> not
> > > ICS
> see
> > > the
> does
> > > see
> me
> > > no
> > > > good)
> > > > Rodney
Let me do a quick reset here-----
Use a DIAL IP HOST Desktop OS W2W
Use a Linksys ROUTER to set Network betwwen Desktop and LAPTOP Win XP
home( wireless network)
Share INTERNET via ICS with the HOST !!
I have looked at the links suggested
QUESTION - Would it not be easier just to replace the ROUTER with an A/P (
if this would get the two PC's to share the dial-up connection and stay
networked )
It's easier for me fly a BOEING that get this working !!!
Thanks in advance
Rodney
> Rodney.
> "Jack" wrote:
> > Hi
> > DHCP.
> > More instructions here: http://www.ezlan.net/router_AP.html > >
> > And here:
> > http://www.microsoft.com/windowsxp [...] 02april08. > > mspx?pf=trueHi
> > > WIN2K O/S - Desktop
> > > THANKS AGAIN
> > > "Jack" wrote:
> > > > Hi
> > you
> > On
> > > > or Off? Etc.)
> > router )
> > > > to
> > not
> > > > ICS
> > see
> > > > the
> > does
> > > > see
> > me
> > > > no
> > > > > good)
> > > > > Rodney
