Archived from groups: microsoft.public.windowsxp.general,microsoft.public.windowsxp.hardware (More info?)
Cross posted to windowsxp.general & windowsxp.hardware.
Follow-ups set to windowsxp.hardware.
I've got a strange boot problem that I can't track down. It began when I
reinstalled XP with sp2 slipstreamed. I do not believe it to be an sp
issue since it continued to occur when I tried re-installing with my sp1
slipstream disk, which has been used for installs several times without
a problem.
First of all, TIA for any suggestions!
* WindowsXP freezes on boot up when the boot screen appears, but instead
of "WindowsXP" turning white it stops when grey. No amount of resets
changes this behaviour. NOTE: This was a fresh install with no change in
the hardware.
* Booting to safe mode works.
* Used MSCONFIG to set /bootlog /sos /basevideo in the boot.ini
* Boot to normal mode works.
* All hard drives were checked for possible errors. No hardware errors
were found. Any file system errors on extra hard drives were fixed by
formatting (not quick) all hard drives.
* Removed the /basevideo setting. System boots fine.
* System runs fine using either default drivers loaded at OS install or
later with the latest manufacturer drivers. Boot freeze occurs one
morning a couple of weeks later
* System worked again after safe mode and replacing /basevideo setting.
NOTE: Something that seems odd is that with the /bootlog and /sos
settings the system shows, at boot, that the drives are scanned. Usually
it only shows the two drives with basic partitions. Occasionally it also
shows the other three drives with dynamic partitions. It seems odd that
the behaviour would vary.
* Below is a comparison of the last portion of the ntblog.txt (the
portion that seems the most surprising to me).
* What I can't figure out is why the hidusb.sys and the mouhid.sys load
so many times in normal boot (which is the boot that I have problems
with), it loads once on safe mode and once in /basevideo mode.
* Fastfat.sys does not load at all in the failed boot.
* NOTE: Over the last few months I've been having mouse freezing
problems. Usually removing all mouse & video software as well as
uninstalling the mouse and USB root will remove the problem…for a time
(and then it returns again).
Here's my hardware:
Video Adapter
Model : RADEON 7200 SERIES AGP
Total Memory : 64MB (64MB Video) (248MB AGP)
Physical Storage Devices
Removable Drive : Floppy disk drive
Hard Disk : IC35L040AVER07-0 (38.3GB)
Hard Disk : ST340016A (37.3GB)
Hard Disk : ST313021A (12.13GB)
Hard Disk : SEAGATE ST173404LW SCSI Disk Device (68.4GB)
Hard Disk : SEAGATE ST336704LW SCSI Disk Device (34.2GB)
CD-ROM/DVD : PIONEER DVD-RW DVR-105 (CD 32X Rd, 16X Wr) (DVD 4X Rd, 2X
Wr)
Peripherals
Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
Mouse : Microsoft USB IntelliMouse Explorer (IntelliPoint)
MultiMedia Device
Device : Santa Cruz(tm)
*Normal boot*
Loaded driver \SystemRoot\System32\Drivers\HTTP.sys
Loaded driver \SystemRoot\system32\DRIVERS\imagesrv.sys
Loaded driver \SystemRoot\System32\Drivers\imagedrv.sys
Loaded driver \SystemRoot\System32\DRIVERS\hidusb.sys
Loaded driver \SystemRoot\System32\DRIVERS\mouhid.sys
Loaded driver \SystemRoot\system32\drivers\kmixer.sys
Loaded driver \SystemRoot\System32\Drivers\Fastfat.SYS
*Failed Boot*
*Safe Mode*
*Boot.ini with /basevideo*
Any ideas?!?
Howie
"The very belief that violence is unavoidable
is a root cause of violence."
Samdhong Rinpoche
1st Democratically Elected Chairman of the
Tibetan Cabinet-in-Exile
a problem.
the hardware.
Here's my hardware:
Video Adapter
Wr)
Peripherals
MultiMedia Device
*Normal boot*
*Failed Boot*
*Safe Mode*
Any ideas?!?
Howie
Samdhong Rinpoche
