Yes No
Ads
Tom's Hardware > Forum > Motherboards & Memory > Elitegroup > K7S5A won't POST with wireless PS/2 mouse
Forum Motherboards & Memory : Elitegroup K7S5A won't POST with wireless PS/2 mouse
Archived from groups: alt.comp.periphs.mainboard.elitegroup (More info?)
I bought this small IR keyboard (with integrated mouse):
http://www.newegg.com/app/ViewProd [...] 23-107-114
The IR transceiver has two PS/2 plugs, one for the mouse and one for the
keyboard. However, when I attach it to my K7S5A it won't POST unless I
remove the mouse plug. I have tried it with my other GigaByte motherboard
and it works fine. Any ideas?
Reply to Anonymous
"John Verdana" <jv2233@greckoroman.com> wrote in message
news:b5ednb3aOM5aE3XcRVn-3g@comcast.com...
Do you have a PS/2 to 9 pin serial adapter? Could you run the machine with
the on-keyboard mouse connected to a serial port? I believe they also make
such adapters for USB so that you can attach a PS/2 device to a USB port.
Eric W.
Reply to Anonymous
"Eric Wolfe" <b_eric_wolfe@yah00.com> wrote in message
news:kfSdnaOY6Z_fR3XcRVn-gw@rcn.net...
> with
> make
Thanks Eric, I was thinking about that. I just wanted to check if there were
any solutions that didn't involve spending money. :-)
Reply to Anonymous
I just bought the same keyboard from Newegg last week. It works fine on my
K7S5A but I disconnected the mouse plug because it isn't practical. I also
had a much older keyboard with int. mouse by same mfr. and had no problems
on K7S5A. It died on me and being good all these years, with excellent
support, is why I bought this one. LiteOn or Silitek, either will give you
prompt service if you need help about this. It's possible you have drivers
floating around somewhat active that go to a different type of mouse? Check
Device Manager in safe mode for duplications, Remove all if so, then reboot
and see if things go smoother.
Reply to Anonymous
"Smoker~" <schmoe@aol.com> wrote in message
news:cZcGd.5765$Vn2.808@trndny06...
> Check
> reboot
The thing is, it will not POST, which means it's a hardware issue. It may be
something to do with the arrangement of cards I have in the machine, or
maybe its because I have an early version of the board. Who knows!
Reply to Anonymous
I'd try erasing the cmos and then I'd try different 'older' versions
of the bios.
PJ
On Sat, 15 Jan 2005 16:12:46 -0500, "John Verdana"
>> Check
>> reboot
Reply to Anonymous
Good idea. I'll try that. Thanks.
"PJx" <me@privacy.com> wrote in message
news:b5dlu0t8lb7l06naok5a5ioake36ffh9fn@4ax.com...
> of the bios.
> PJ
>>>> the
>>>> motherboard
>>> my
>>> also
>>> problems
>>> you
>>> drivers
>>> Check
>>> reboot
>>be
Reply to Anonymous
There are 1921 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Difference between 2133 (O.C.) and 2133 for DDR3 RAM.
By stickg1, 3 hours ago:
Nice CPU, you can use 2133 RAM, you will have to manually set it to that speed in the...
Best offers
Top experts
