Archived from groups: alt.comp.periphs.mainboard.elitegroup (More info?)
Hello all,
I have a 2.4 (AMD Athlon) processor in my PC, well it's been running
slow so I looked at the settings in the control panel, and saw that it
said it was only running at 1.49. When I first got the PC (my old man
built it), it had this problem, so at that time I went into the
settings during boot, went the the speed configurations settings and
changed the speed. Now last night I couldn't remember exactly what I
changed it to, I thought ot was 166/133. Well I changed to to that
(from 100/100), now the PC will power up, but I don't hear the "beep" I
normally hear when when it starts up, there are no lights/activity on
my keyboard, or mouse, and the monitor just displays a "test" message.
My two disk CD drive bays will open & close. The motherboard is a ECS
Elitegroup K7S5A PRO REV:5.0. Of course, I no longer have the owners
manual. I am running XP Pro. Last night I unplugged the PC from the
wall and removed the battery for about an hour, hopping this might have
reset the system, it didn't. Any words of wisdom?
<scottandadrianna@yahoo.com> wrote in message
news:1113226387.328864.292890@z14g2000cwz.googlegroups.com...
> Hello all,
You can download the manual from ECS.
http://www.ecs.com.tw/ECSWeb/Downl [...] 35&LanID=0 In the manual, it says that if you manually set the wrong speed and the system
won't run properly, press the Page Up key while the system is booting and a
default setting will replace the incorrect CPU setting.
The recommended setting for your PC would be 133/133.
Did you try using the Clear CMOS jumper?
It is on the JP4 and you jumper 1-2 to clear and 2-3 is Normal.
"Buffalo" <eric(nospam)@nada.com.invalid> wrote in message
newsu6dnSkQGeBmIMffRVn-uw@comcast.com...
http://www.ecs.com.tw/ECSWeb/Downl [...] 35&LanID=0 > In the manual, it says that if you manually set the wrong speed and the system
Sorry, you MB has the Clear CMOS jumper on JP1, not JP4.
However, 1-2 is still to clear, and 2-3 is Normal.
I just dl'd your manual, and you should do the same.
Thanks so much!!!
> > Hello all,
running
it
man
and
I
"beep" I
on
message.
ECS
owners
have
the system
and a
