Tom's Hardware > Forum > Motherboards & Memory > Elitegroup > OnBoard Sound Problems - K7vta2 V2.2 (pete reply problem)
Forum Motherboards & Memory : Elitegroup - OnBoard Sound Problems - K7vta2 V2.2 (pete reply problem)
Archived from groups: alt.comp.periphs.mainboard.elitegroup (More info?)
"K7vta2 Ver2.2
Using XP
I know little about this board as I got it 2nd hand.
it did not come with a driver CD so tried and installed the sound
drivers off the website...
However I just can’t get sound to work. It is enabled in the bios.
The drivers seem to load and when runing a .wav for example soundrec
will come up and show the wav but no sound will come out and only a
second or two of the wav seems to be processed.
Any ideas where I can get a copy of the original drivers from?
Regards
Pete
spamblocking"
down load the manual. there are jumpers for the audio rear or front
panel connection. if those jumper aren’t there or set for the front
your rear out won’t work.
also check in control panel multimedia/sound make sure mute is engaged
also the mixer, etc.
http://www.ecsusa.com/downloads/manual_k7v.html
ud
Posted using the http://www.hardwareforumz.com interface, at author's request
Articles individually checked for conformance to usenet standards
Topic URL: http://www.hardwareforumz.com/Elit [...] 58641.html
Visit Topic URL to contact author (reg. req'd). Report abuse: http://www.hardwareforumz.com/eform.php?p=297015
Sponsored Links
On 9 Jul 2005 02:42:13 -0400, uddarts
<UseLinkToEmail@HardwareForumz.com> wrote:
Cheers. That's useful information. I'll give it a look.
Thanks.
Pete
Spamblocking
>ud
Reply to Pete
There are 647 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
