Archived from groups: alt.comp.periphs.mainboard.epox (More info?)
Will this ram work with EP-8RDA3+revision 2.0 whats the latest
revision anyway ??
EP-8RDA3+
TWINX1024-4000PRO 1GB DDR Kit
What Corsair has to say about the TWINX1024-4000PRO:
"The TWINX1024-4000PRO is a 1 GByte matched memory pair specifically
designed for motherboards using chipsets with dual memory channels.
This memory kit consists of two CMX512-4000PRO memory modules that
have been tested together on an 875P dual channel DDR motherboard at
DDR500 (250 MHz). TwinX memory kits are designed to provide the
ultimate in performance and stability in dual channel boards. As part
of Corsair's new XMS ProSeries, each module includes the new
high-efficiency aluminum XMS heatsink, and 18 activity LED's that show
the level of memory activity on each bank."
Latest revision is 3.1 just got the info from epox.
TWINX1024-4000PRO Features:
1024 Megabytes of memory - Two matched CMX512-4000PRO modules
New high-efficiency aluminum XMS heatsink
95% greater surface area than standard memory heatspreaders
Thermally bonded to the module
18 activity LED's show level of memory activity
Benchmarked over multiple chip sets, processors, and motherboards
Tested and packaged in pairs
Modules tested together in an Asus P4C800 test setup
Tested at DDR500 (250MHz)
Tested at JEDEC-standard latency settings (3-4-4-8)
Test voltage 2.75V
Plug-n-FragTM Auto-Configuration
Boots automatically using latency values optimized for bus speed
SPD programmed at JEDEC PC3200 values
Legendary Corsair reliability and service
Lifetime warranty
TWINX1024-4000PRO Specifications:
Part Number: TWINX1024-4000PRO
Speed: 500 MHz (PC4000)
Size: 1024MB (2 x 512MB)
Package: 2 x 184 DIMM
Latency: 3-4-4-8
32M x 8 DDR SDRAMs
Dimensions: Approximately 1.75" tall x 5.41" long x 0.30" wide; 2.9 oz
Expensive ram would like it to work, do you have a list i can look at
to see ram compatibility ??
If anyone is running this ram in this board please let me know on how
its going any problems, as i might have to settle for pc3200 OH MY GOD
