Tom's Hardware > Forum > Motherboards & Memory > Epox > A "slight" problem with 8KRAi's CPU Clock settings
Forum Motherboards & Memory : Epox - A "slight" problem with 8KRAi's CPU Clock settings
Archived from groups: alt.comp.periphs.mainboard.epox (More info?)
Hiya,
I try to make this as short as possible :)
As you can see, I'm using 8KRAi motherboard and AMD Athlon XP 2400+ as
my processor and I have the following problem with the system setup:
Earlier today, when I was configuring my system for the very first
time I noticed that my motherboard recognized my processor as a
Athlon XP 1500+ (or something like that, can't remember accurately) I
took a look at the PowerBIOS settings which hold the configuration to
the FSB and CPU Clock settings, and I noticed that the multiplier was
configured as "Auto" or similar and the system bus was operating only
at 100 MHz. So I came into the following conclusion: as the CPU:s
operating frequency is supposed to be 2.0 GHz I changed the
multiplier to 10x and the system bus to 200 MHz. (10 x 200 = 2000
aight?) After that my system wasn't bootable. The manual stated that
if a problem occurred due false overclocking configuration (which
mine apparently was?) the screen goes blank and can be returned to a
initial configuration by instantly pressing Insert. Unfortunately I
didn't have that part of the manual open at that moment and when the
screen just went blank I rebooted. The question is that should I have
pressed Insert at the very moment that the screen went blank? Is
there anything to do to revive my system back to life?
Thanks in advance :)
Posted through www.HowToFixComputers.com/bb - free access to hardware troubleshooting newsgroups.
Sponsored Links
"Sorgemus" <jarrerules@sunpoint-dot-net.no-spam.invalid> wrote in message
news:41069a28$1_6@news.athenanews.com
> Hiya,
Set the FSB to 133(266) and leave multiplier to Auto - then it should work!
Keep Insert pressed while switching the system on - you are not returning to
the initial config but kinda Safe bios settings as far as I know. In other
words you have to config the whole bios back to Normal settings. In case the
Insert key does not work as expected u can remove or "short" the batterie
(see manual) which has the same effect (resetting the bios).
hth
Steve
Reply to Anonymous
Hi
Power off.
Press and hold insert then apply power. Keep INSERT held until you get a
screen then enter the BIOS and reset the CPU settings.
Assuming your AMD XP2400+ is a Model 8 then you should use...
133Mhz FSB for CPU (266) and set ratio to autio.
Technical Support Department
EPoX International, Inc.
support@epox.com
www.epox.com
Visit the EPoX store for all those hard to find motherboard accessories...
BIOS chips, heatsinks, cables, and much more! https://www.epoxstore.com
news:41069a28$1_6@news.athenanews.com...
> Hiya,
Reply to Anonymous
There are 536 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
