G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.epox (More info?)
Hi,
I have an OLD Epox motherboard, a "P55TV2". I've been able to download
the motherboard manual from Epox's NL website:
www.epox.nl/manuals/p55tv2.pdf
I know that this motherboard is working, but I had taken it out of the
computer case, and, in reviewing the above manual, it shows the main
power connector on the board layout, but there is no information on the
pinout of the power connector.
The power connector on the motherboard is a 12-pin male connector.
From the power supply, I have two white 6-pin connectors, but I cannot
tell which of these two connectors goes into the left vs. right-side of
the power connector on the motherboard.
As I mentioned, I know that this is a very old motherboard, but I was
wondering if there is any possibility that anyone might be able to
advise me of the pinout of the power connector on the motherboard?
I have the color code for the wires to the power supply connectors, so I
should then be able to figure out which connector goes where.
Also, the CPU on the board is a Pentium MMX 233, and I was wondering if
anyone could confirm that the proper jumper settings for this CPU are:
JP5: 10-23
JP6: 1-2
My apologies for these questions, but I hope that someone here can help
me.
Thanks in advance!!
Jim
Hi,
JP5: 10-23
JP6: 1-2
me.
Thanks in advance!!
Jim
