News
Colombia Signs Up For 65,000 OLPC Laptops
Published on May 30, 2008
Colombia has become the latest country to sign up for the One Laptop Per Child program. Read more
Apple releases Boot Camp beta update
Published on August 16, 2006
Apple today released version 1.1 beta of its Boot Camp software that allows Apple users to run MacOS X side by side with Windows XP on an Intel-based Mac. Read more
Ultra-X introduces harddrive cleaning utility
Published on June 29, 2004
Ultra-X, known for its professional hardware and software diagnostic tools, has introduced a simple, OS-independent tool to safely erase data from IDE harddrives. Read more
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
Published on January 01, 2009
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
System Builder Marathon: $2,500 Enthusiast PC
Published on December 31, 2008
We’ve seen how far a moderately priced Core i7 system can take us and now we’re ready to assess the performance advantages of better cooling and a stronger graphics configuration. Will our upgrades be worth the money? Read more
System Builder Marathon: $1,250 Mid-Range PC
Published on December 30, 2008
We see how far $1,250 gets us when building a new Core i7-based system, and how it compares to last month’s similarly priced Core 2 Duo machine. Read more
SSDs Replacing HDDs Soon? Not A Chance
Published on December 29, 2008
Some say 2010 and even 2009 will be the year of SSDs. We think not. Read more
  Tom's Hardware Forums » Motherboards & Memory » Epox » 8KRAI Problem: Won't boot from primary IDE1 on fresh insta..
Word :   Username :
Bottom
Author
 Thread : 8KRAI Problem: Won't boot from primary IDE1 on fresh insta..
More Information
Archived from groups: alt.comp.periphs.mainboard.epox (More info?)
This one is a weird one. I boot XP from the Setup CD, run the
installer, format full NTFS (not Quick Format), XP CD copies the setup
files to C:, restarts and gives an error message of BOOT DISK ERROR -
INSERT BOOT CD on 1st boot. BIOS setting for boot sequence is 1)
Floppy, 2) Hard Drive 3) CDROM. If I allow it to detect the WinXP CD
in the CDROM drive but not boot from it, it does boot from primary
IDE1. Anyone have this problem? Any help would be appreciated. BIOS is
at 8/10/04.
- Pavlov
Check out my pics!
http://www.neiu.edu/~akkoziol
Related Product
More Information
"Pavlov" <.@.> wrote in message
news:8p2fl0lml0nd9vhn00khps3crakag2r2eo@4ax.com...
> at 8/10/04.
Surely you should have the CDRom as second boot (or instead of)
the floppy drive? When the restart happens after the HDD has been
prepared, it still is not a working OS for any purpose.
Graham W http://www.gcw.org.uk/ PGM-FI page updated, Graphics Tutorial
WIMBORNE http://www.wessex-astro-society.freeserve.co.uk/ Wessex
Dorset UK Astro Society's Web pages, Info, Meeting Dates, Sites & Maps
Change 'news' to 'sewn' in my Reply address to avoid my spam filter.
More Information
>> at 8/10/04.
Thanks for your reply. Yep, I've tried switching off all other boot
device options so that only the HD is selected as the 1st boot device
but still nothing happens. It always says Boot Disk Error even if I
remove ALL devices from the IDE1 channel and just have primary IDE1
master attached. So to answer your question, after XP has prepared the
HDD it is still not booting into a working OS. Last night I tried
another HD that I allowed XP setup to format completely and install but
it gave the same error. I even changed out the DDR memory with different
brand and nothing changed. I am pretty convinced now that it is the
motherboard. I have built computers for over 10 years and this is the
first time this one ever happened to me. ha ha.
- Pavlov
Check out my pics!
More Information
>>> setup files to C:, restarts and gives an error message of BOOT DISK
>>> ERROR - INSERT BOOT CD on 1st boot. BIOS setting for boot sequence
>>> is 1) Floppy, 2) Hard Drive 3) CDROM. If I allow it to detect the
>>> WinXP CD in the CDROM drive but not boot from it, it does boot from
>>> primary IDE1. Anyone have this problem? Any help would be
>>> appreciated. BIOS is at 8/10/04.
> but it gave the same error. I even changed out the DDR memory with
> different brand and nothing changed. I am pretty convinced now that
> it is the motherboard. I have built computers for over 10 years and
> this is the first time this one ever happened to me. ha ha.
No, you mis-understand. You must continue to boot from the CDRom
until the installer tells you to remove the CD and boot from the HDD.
The computer needs to reboot so that the disc parameters can be
recorded by the BIOS after formating. But there isn't an OS there yet.
More Information
Graham,
Even if I run the setup all the way to the end of a fresh install of XP
(windows desktop) with CD enabled in the BIOS or not, it still will not
boot off the primary IDE drive. If you dump a fresh install of XP onto
an HD that is recognized in the BIOS already, it doesn't have anything
more to do with the BIOS. Are you referring to the MBR? XP setup and
BIOS parameters are mutually exclusive my friend. In any case, I have
determined it to be a defective motherboard and will harass Epox for a
replacement. Thanks for your help.
- Pavlov
Check out my pics!
Google Ads
