Archived from groups: alt.comp.periphs.mainboard.epox (More info?)
After installing my new AthlonXP2600 CPU in my 8Kha+ (Rev 2.0), I got a
message upon boot-up to adjust my BIOS settings. At boot-up, it showed
that this CPU wanted to run at 133x16 (2.128ghz), so I tried upping the
multiplier to 16 and found that my BIOS only went as high as 15 for the
multiplier.
Therefore, I figured that I needed to flash my BIOS, so I put my old CPU
back in (Athlon XP2100), then downloaded the latest BIOS from the Epox
site (8KHAI3425 dated 4/25/03). I then successfully flashed the BIOS
using the floppy disk method. I rebooted and loaded Optimized Settings
(per the flashing instructions), saves the settings and re-booted again.
I then checked the BIOS settings and found that the multiplier is
still limited to 15 as the highest value!
So, I haven't re-installed the new CPU yet, since it appears that the
necessary multiplier is still not supported in the BIOS.
Is there a more up-to-date BIOS available somewhere? Or is there
something I'm doing wrong?
The Epox website states that this motherboard supports this CPU, but the
BIOS settings appear not to. Any help with this would be GREATLY
appreciated!
BRH <BRH> wrote in news:07ednawW-ZtbFXfcRVn-rg@comcast.com:
try 8
You can find 8KHI3916 (16 Sep 2003) from the european site
<http://www.epox.nl/english/support/bios/bios.php?id=236>
Peter Strömberg (55.6N 13.0E)
C2K2 C2K3 ISCCIV02 ISCCIV03 ISCCIV04
<BRH> wrote in message news:07ednawW-ZtbFXfcRVn-rg@comcast.com...
> multiplier.
> (per the flashing instructions), saves the settings and re-booted again. I
> then checked the BIOS settings and found that the multiplier is still
> appreciated!
BRH,
Use *8X* multiplier to get actual 16X multi !
Matt
I will give 8X a try. Thanks!
>>multiplier.
>>appreciated!
> BRH,
> Matt
>>multiplier.
>>appreciated!
> BRH,
> Matt
Out of curiousity --- With the new BIOS loaded, why wouldn't the default
multiplier setting of "Auto" work?
<BRH> wrote in message news:r6WdnQGiS8cVaHfcRVn-gg@comcast.com...
>>>multiplier.
>>>I then checked the BIOS settings and found that the multiplier is still
>>>appreciated!
>> BRH,
>> Matt
BRH,
Can`t answer, too technical... plus.... I forgot, but check out this old
link!!!
This worked for me "back in the day".
http://forums.pcper.com/showthread [...] tcount=865 Scroll down to about the middle of the page to : "XRAYIFIX" and start
reading!!
I have had my (unlocked T-Bred) XP2400+ overclocked to 2.24 GHz now for
almost two years now using *8X* (16X) times 139 MHz.
>>>>multiplier.
>>>>appreciated!
>>>BRH,
>>>Matt
> BRH,
> link!!!
> http://forums.pcper.com/showthread [...] tcount=865 > Scroll down to about the middle of the page to : "XRAYIFIX" and start
> reading!!
> Matt
> Matt
Interesting read. Thanks!
>>> a message upon boot-up to adjust my BIOS settings. At boot-up, it
>>> showed that this CPU wanted to run at 133x16 (2.128ghz), so I tried
>>> upping the multiplier to 16 and found that my BIOS only went as high
>>> as 15 for the multiplier.
>>> CPU back in (Athlon XP2100), then downloaded the latest BIOS from the
>>> Epox site (8KHAI3425 dated 4/25/03). I then successfully flashed
>>> the BIOS using the floppy disk method. I rebooted and loaded
>>> Optimized Settings (per the flashing instructions), saves the
>>> settings and re-booted again. I then checked the BIOS settings and
>>> found that the multiplier is still limited to 15 as the highest value!
>>> the BIOS settings appear not to. Any help with this would be GREATLY
>>> appreciated!
>> BRH,
>> Matt
Yup. It worked! 8-)
