Archived from groups: alt.comp.periphs.mainboard.epox (
More info?)
Hi, Sharp.
If you want to use that SATA drive as your boot device, then drivers for it
must be integrated into your copy of WinXP during Setup. And the only way
provided to do this is to run WinXP Setup again, press F6 when invited, and
let Setup install it from a floppy diskette. This is not necessary for a
SATA drive to be used as a secondary drive, but it is required to use it as
the boot device. Even if you use something like Ghost, the ghosted drivers
on your new drive will be the ones for your old boot device, not for your
new SATA drive, and you'll still need to run Setup again.
The only way WinXP Setup knows to get drivers that are not included on the
WinXP CD-ROM is to load them from a floppy diskette. My EPoX 8KDA3+ came
with onboard SATA RAID, but I don't use either SATA or RAID yet. (I boot
from SCSI and have 2 IDE drives for data.) So I haven't installed SATA
drivers, but I did have to use the F6 and floppy to install drivers for my
SCSI host adapter.
My 8KDA3+ User's Manual has instructions (in Section 5, S-ATA RAID
CONFIGURATION) for how to "Prepare driver floppy" from the drivers on the
CD-ROM that came with the mobo. Your 8RDA3+ probably has similar
instructions. I haven't had to try it yet, but I expect that I will need to
do this when I install a SATA drive - even without RAID - as my boot device.
When you have the floppy ready, boot from the WinXP CD-ROM. During the
hardware detection phase, early in Setup, watch for the message that flashes
briefly at the bottom of the screen to Press F6 to install mass storage
drivers, or something to that effect. Press F6, then wait. Setup will seem
not to notice and will continue copying hundreds of files; then it will stop
with instructions for using that floppy to install the drivers. After that,
Setup will boot from that SATA drive for the first time and run the GUI
phase to complete the installation.
> I dont want to re-install winXP.
You'll want to do an "in-place upgrade", also known as a repair install.
This completely reinstalls WinXP itself, but preserves your installed
applications and data - and most of your tweaks. The official instructions
for this are in this KB article:
How to perform an in-place upgrade (reinstallation) of Windows XP
http://support.microsoft.com/default.aspx?scid=KB;en-us;q315341
Follow the instructions for Method 2 and note that you do NOT press "R" for
Repair the first time it is offered, in Step 3. Press Enter here and then
"R" when you get to Step 5. You might prefer MVP Michael Stevens' version
of the same instructions:
http://michaelstevenstech.com/XPrepairinstall.htm
Either way, of course, you'll want to visit Windows Update as soon as you
get your firewall and antivirus back in place to be sure that you have all
critical updates.
If you find a quicker and/or easier way to handle this, please let us know.
RC
R. C. White, CPA
San Marcos, TX
rc@corridor.net
Microsoft Windows MVP
"Sharp" <Sharp@SharpAddress.com> wrote in message
news:ZxVXd.191865$K7.116906@news-server.bigpond.net.au...
> Hi
> I have an Epox 8RDA3+ rev1.x motherboard.
> WindowsXP fails to detect my Western Digital SATA HDD.
> Have latest BIOS.
> Enabled SATA in BIOS.
> SATA is set to the first boot device.
> Been told that you have to install the SATA driver during XP installation.
> If I have already installed winXP, then what I can do about this?
> Cheers
> Sharp
