Archived from groups: alt.comp.periphs.mainboard.epox (More info?)
My old MB died and I switched back to my 8RDA+. After
installing windows, I'm having problems with XP seeing my
audio device. When I go to "Control Panel -> Sound and
Audio Devices", on the 'Audio' tab it is showing "No Playback
Devices" under default device and the select box is greyed out.
The same is true for the default device for "Sound Recording"
but the default device for "MIDI music playback" is set to be
'MPU-401' with no other option available.
Under the 'Hardware' tab, it is showing the following devices:
MPU-401 Compatible MIDI Device
Standard Game Port
Realtek AC'97 Audio
NVIDIA(R) nFormce(TM) MCP Audio Processing Unit
Audio Codecs
Legacy Audio Drivers
Media Control Devices
Legacy Capture Devices
Video Codecs
Clicking the 'Properties' button for each shows that the device
is working correctly. Going into the device manager shows the
following devices:
Audio Codecs
Legacy Video Capture Devices
Realtek AC'97 Audio
Standard Game Port
Video Codecs
none of which have the yellow question mark by them. I've gone
to the Epox site, downloaded and installed all the latest drivers
but for the life of me I can't figure out why it's not showing anything
that can be used to play sound.
Any help, ideas or suggestions would be greately appreciated!
You installed the wrong motherboard driver (whether it be your fault or Epox). You should not have "Realtek AC'97 Audio" in device manager. In it's place you should have "Nforce Audio Codec". I use this driver set with my 8RDA+ and it works well. http://www.nvidia.com/object/nforc [...] _2.45.html
DaveL
"Christoph" <jcboget@yahoo.com> wrote in message news:4YOdncP8ie31J8rfRVn-gw@eatel.net...
> Standard Game Port
> Realtek AC'97 Audio
> Audio Codecs
> Video Codecs
> following devices:
> Audio Codecs
> Realtek AC'97 Audio
> Standard Game Port
> Video Codecs
> thnx,
> Christoph
